  4. Ford Truck Recall...
33 Posts 14 Posters 1.8k Views
    Oh and I am sure that none of you bothered to look into what hose it is that is recalled. It is not a brake line....
      ...or it took you seven days to figure that out. 🙂
        Defect Summary:
        FORD IS RECALLING 605,684 MY 2005-2006 F-150 AND LINCOLN MARK LT VEHICLES EQUIPPED WITH 5.4L 3-VALVE ENGINES. THE BRAKE BOOSTER VACUUM SUPPLY HOSE ATTACHED TO THE INTAKE MANIFOLD FITTING MAY SWELL OVER TIME AND LOSE RETENTION FORCE. THIS CONDITION COULD ALLOW THE HOSE TO BECOME DETACHED FROM THE FITTING DURING AN INTAKE MANIFOLD BACKFIRE. SHOULD THE HOSE DETACH FROM THE INTAKE MANIFOLD, SEVERAL BRAKE APPLICATIONS WITH POWER ASSIST WILL BE AVAILABLE BEFORE THE VACUUM RESERVE IS DEPLETED.
        Consequence Summary:
        ONCE THE BRAKE BOOSTER VACUUM RESERVE IS DEPLETED, THE DRIVER WILL HAVE FOUNDATION BRAKE FUNCTION, BUT WITH INCREASED BRAKE PEDAL EFFORT. REDUCED VEHICLE BRAKING COULD LEAD TO A CRASH.
        Corrective Action:
        DEALERS WILL REPLACE A RUBBER HOSE ON THE BRAKE BOOSTER VACUUM SUPPLY TUBE ASSEMBLY. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT JULY 7, 2008. OWNERS MAY CONTACT FORD AT 1-800-392-3673.
          tjamz;219752 wrote:
          Hence the reason I buy Toyota....made here by American workers.
          yup, and owned by people that hate us.... and fueled by people that want us to convert or die....
          lol
            lol
            You dick, you ruined the suspense by posting the recall info
              SmitEvo;218920 wrote:
              Bad brake lines or something...
              http://www.msnbc.msn.com/id/24619177
              So how is a vacuum booster hose a bad brake line?
                It isnt...it was the "or something".
                  Looks like they have another recall....projected profits. 🙂 Poor Ford...
                  http://www.msnbc.msn.com/id/24773925
                  • kylushK Offline
                    kylushK Offline
                    kylush
                    Parker;219801 wrote:
                    Defect Summary:
                    Corrective Action:
                    This exact same thing happened to our 05 F-250 work truck last summer. Just cruising around and all the sudden the peddle was just like rock hard and you had to freakin stand on it to get any stopping power at all. Kinda scary...
                    Course that thing had lots of problems, two injectors, fuel pump, and the transmission all had gone out on it by the time it had 30,000 miles on it
                    1998 Z28 Camaro
                      Was that a diesel or a gasser?
                      • ErikE Offline
                        ErikE Offline
                        Erik
                        I've already had several people in for this problem.
                        Apparently they'll be reimbursed for the previous repair.
                        They call me, old man...
