  4. Project: putting a real motor in a RX-7
79 Posts 24 Posters 3.9k Views
    btleier;219893 wrote:
    lots of room in the for other neat stuff.
    TRADER!
    Ha, yeah that electric pump made alot of room..... room enough for two of something to fit 😉
    94NDTA;219910 wrote:
    Maybe it's some crazy technique he is using to turbo it.
    Or he was drunk...
    Actually i am going with a FMFC.............. Front Mount Fart Can...... supposed to be wicked, and i was drunk..ha
    and +1 for injectors
      How big are the injectors?
        how cheap are parts for motor?
          WAAAAYYYYY Cheaper. Not that it matters... They are very stout engines. They also weigh very close if not, less than a rotary. (That's what I read)
            60#
            not as cheap as Gen I-II stuff.... but not ridiculous
            I will do a run down list of what i have paid sometime.....lets put it this way
            I have sold most of my rotary stuff..... and with that money i have not spent a penny more on anything for this setup thus far.........
            these engines will do 600 wheel stock so that is very stout for an engine with cast parts
            I have an iron block... so around 80lbs heavier than the alum. ls1/ls2 engines
            but I feel well worth it for the durability gained..... heck GM doesnt recommend boring the alum. blocks .010"+ over because of the thin liners........ where as the iron 4.8/5.3 blocks can be bored .100" over
            Since all the genIII-IV engines share the same cylinder spacing it is only common sense that the smaller bore versions are going to have thicker cylinder walls and inherently more strength with boosted applications
            IMO alum. blocks are overated...my car is a lightweight anyway...80lbs... bigdeal
            ya rambling again
              had lots of time today
              got the pushrods back in, intake, TB, elbow all done
              and got the harness perty much whipped
              but good news...
              cranked it over till i got 40psi cranking...... had good spark and could hear the injectors, so my harness is good to go 🙂
              missing some fittings to hook up my fuel supply, but a little carb cleaner down the hole and she fired to life ..... so good news, darn excited, different sound that is for sure
              anyway here is what came out of the stock harness
              pic of accomplishments today
              and hood clearance or lack of for those curious, and squawsnatch playing with himself
                Just reuse your sticky scoop haha.
                • ChristianC Offline
                  ChristianC Offline
                  Christian
                  Nice progress! Mine just started yesterday what a good feeling!
                  Playtime Performance
                  06 F-150 Lariat
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    Looking good!! Can't wait to see it with some snails...
                      So...... you are going to have to make 3 holes in the hood on this one??????
                        so lots of progress..
                        perty much done with the NA stage.... see what it will do NA and then time for turbos
                        hmm what to list
                        temporary exhaust dumps till turbo time
                        sexy alt relocation setup
                        lots of other stuff.....
                        all it needs is a shifter, and some tunning
                        anywho it runs..... great 🙂
                        and short walk around vid (crappy)
                        http://www.youtube.com/watch?v=gPlGAXpRec4
                          nice! glade to see it running!
                            Looks sweet. Whats all done to the motor again? Just stock NA?
