  4. The Del's done!!!
The Del's done!!!
71 Posts 29 Posters 6.5k Views
  • 3_Series3 Offline
    3_Series3 Offline
    3_Series
    Looks good!
    2002 Subaru Legacy
    1993 BMW 325i (sold)
      When is it going to come out to the track?????????
      • D S ohMD Offline
        D S ohMD Offline
        D S ohM
        Needs slicks yo.
        I wanna go fast!
        • C Offline
          C Offline
          CivicEX7777777
          bubba;228730 wrote:
          His car is sitting with a timing belt ready to snap and his second axle fucked... and has also been put up fs/ft... been focusing on the wago lately...
          I saw the del sol at tm the other day... engine bay looked amazing, very good job
          Whhhaaat hes selling it?! How much is he asking!?
          2007 Pontiac G5
          2007 Yamaha C3
          2002 Oldsmobile Alero
          1994 Nissan Sentra
            D S ohM;228818 wrote:
            Needs slicks yo.
            Slicks are for pussies.....
              ........ says the guy who must get off on 2.4XX 60ft times.......
                Yap, burnouts are fun.
                  meh... the launch is the best part period...... as you would know if you had ever felt any sub 1.6xx launch..... well, sub 2.00 for you I spose
                    Im not man enough for RWD....
                    btw, travis has no problem pulling 1.7s on a very simple setup.
                      must be a pussy for not looking like a retard and actually using slicks.... aye?
                      on track................ is the del a 5 speed?
                        I could care less, my car is being built for show.
                        And obviously the del sol is a 5 speed.
                          and obvoiusly you are a fucking tool....... are you positive it isn't "missing" a gear??
                            Why are you being such an ass?? Im just havin some fun and haven't been mean to you at all. Anyways, unless it is a custom tranny, all b-series manuals are 5 speed.
                              sorry i am being a big old meany...... tissue???
                              so Mr. "obvious" did you find out if it is a 5 speed yet??
                                Im going to assume that it is a 5spd unless it is custom, in which case you probably already knew that and wouldn't have asked.
                                  No, I am just piecing together......
                                  because i know that valve cover with the two large fittings welded on........and i am not a honda guy
                                  Mr. O...... is that not a very unique valve cover??? you of all knowing honda knowledge should know??
                                    When have i claimed to know everything about hondas??
                                    And yes the valve cover is unique for around here and custom, but venting like that is pretty common on high horsepower hondas.
                                      just giving credit where do??
                                      So, where have you seen "that" or a nearly identical valvecover before??? possible to be local??
                                        Yes it is GSRs old motor i believe.
                                          my conclusion also......
                                          so would it be fair to bet that just maybe GSR's tranny made it in there too??
                                          the one without 5th gear, and in its place a whatever sort of clamp that holds the two main shafts from spreading
