  4. 100+ Octane unleaded?
62 Posts 21 Posters 5.6k Views
    I had heard that Brady's in moorhead sells it at the pump, not sure though
      yup they do have a pump for 100octane unleaded...its like 5.99 a gallon tho....
      • My NOvaM Offline
        My NOvaM Offline
        My NOva
        doesnt proformance auto sell 104 unleaded i think they do
        Hey Tina come get some hamm
          For someone who drives an s4, it aint no thang.
          • My NOvaM Offline
            My NOvaM Offline
            My NOva
            nah i think some one helps him out though 😄 😄 the c.e.o
            • F Offline
              F Offline
              fanaticrockford
              toulene is the #1 chemical in race fuel. it has a 114 octane rating.
              Heres some info on it.
              Toulene
              R+M/2...114
              Cost...$2.50/gal
              Mixtures with 92 Octane Premium
              10%...94.2 Octane
              20%...96.4 Octane
              30%...98.6 Octane
              Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 points, I.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
              Q: Will my car benefit from octane boosting?
              A: Consumer organizations have effectively emphasized the larger markups that oil companies charge for high octane gasoline, implying that for most vehicles higher octane fuel is a complete waste of money. It has been quite a long time since the consumer alert was issued. Since then engine technology has evolved greatly, while people's perceptions generally have not.
              Modern vehicles now use computerized engine management systems that can react to engine knock and retard ignition timing if low octane fuel is being used. Consequently cars are now being manufactured with very high compression ratios that appear to give good fuel economy and at the same time good performance. This combination does assume that fuel of adequate octane is being used.
              Q: Why bother to boost octane at all since my engine can run just fine on lower octane fuel?
              A: For a high compression engine to run on low octane fuel, the engine management system will need to retard the ignition timing to prevent preignition or pinging. Retarding the ignition timing means that the firing of the spark plug is delayed until a later moment in the compression stroke. It does not take much to see that a later onset of combustion means that the combustion is less complete, which in turn mean less power and poorer fuel economy. It is possible that the casual driver will still come out ahead in terms of saving money by using low octane fuel, but the retarded ignition advance also means a rougher running engine and a much duller throttle response. Thus octane boosting is not necessarily of interest to all motorists but rather the enthusiasts.
              For turbocharged or supercharged engines, insufficient octane will also lead the engine management system to curtail the amount of boost which in turn defeats the purpose of these engines.
              Q: How did you discover using toluene?
              A: Someone came across a web page that described various DIY home brew octane booster formulas. One of which used toluene as its main ingredient. As a Formula 1 racing fan of many years, I recalled that toluene was used extensively in the turbo era in the 1980s by all the Formula 1 teams. The 1.5 liter turbocharged engines ran as much as 5 bars of boost (73 psi) in qualifying and 4 bars (59 psi) in the actual race. Power output exceeded 1500bhp, which translates into 1000bhp/liter, an astronomical figure.
              A motorsports journalist, Ian Bamsey, was able to obtain Honda's cooperation for his book "McLaren Honda Turbo, a Technical Appraisal". The book documents the key role that the toluene fuel played in allowing these tiny engines to run so much turbo boost without detonation. The term "rocket fuel" originated from the Formula 1 fraternity as an affectionate nickname to describe its devastating potency. Thus I concluded that I should focus my research on using toluene for my octane boosting project.
              Individuals with good long term memory will recall that when unleaded gasoline was first introduced, only low octane grades were available. While it is not entirely clear that high octane super unleaded gas came about as a result of the advances in fuel technology in Formula 1, there is every reason to suspect that this is indeed the case, since many of the major oil companies were involved in the escalating race to develop increasingly potent racing fuel during this era.
              Q: Why do you think toluene is better than other types of octane boosters?
              A: Several reasons:
              Mindful of the evil reputation of octane boosters in general, toluene is a very safe choice because it is one of the main octane boosters used by oil companies in producing ordinary gasoline of all grades. Thus if toluene is indeed harmful to your engine as feared, your engine would have disintegrated long, long ago since ordinary pump gasoline can contain as much as 50% aromatic hydrocarbons.
              Toluene is a pure hydrocarbon (C7H8). i.e. it contains only hydrogen and carbon atoms. It belongs to a particular category of hydrocarbons called aromatic hydrocarbons. Complete combustion of toluene yields CO2 and H2O. This fact ensures that the entire emission control system such as the catalyst and oxygen sensor of your car is unaffected. There are no metallic compounds (lead, magnesium etc), no nitro compounds and no oxygen atoms in toluene. It is made up of exactly the same ingredients as ordinary gasoline. In fact it is one of the main ingredients of gasoline.
              Toluene has a RON octane rating of 121 and a MON rating of 107, leading to a (R+M)/2 rating of 114. (R+M)/2 is how ordinary fuels are rated in the US. Note that toluene has a sensitivity rating of 121-107=14. This compares favorably with alcohols which have sensitivities in the 20-30 range. The more sensitive a fuel is the more its performance degrades under load. Toluene's low sensitivity means that it is an excellent fuel for a heavily loaded engine.
              Toluene is denser than ordinary gasoline (0.87 g/mL vs. 0.72-0.74) and contains more energy per unit volume. Thus combustion of toluene leads to more energy being liberated and thus more power generated. This is in contrast to oxygenated octane boosters like ethanol or MTBE which contain less energy per unit volume compared to gasoline. The higher heating value of toluene also means that the exhaust gases contain more kinetic energy, which in turn means that there is more energy to drive turbocharger vanes. In practical terms this is experienced as a faster onset of turbo boost.
              Chevron's published composition of 100 octane aviation fuel shows that toluene comprises up to 14% alone and is the predominant aromatic hydrocarbon. Unfortunately composition specifications for automotive gasoline is harder to pin down due to constantly changing requirements.
              Chevron's web site also describes the problems of ethanol being used in gasoline.
              MTBE was heavily touted as a clean additive several years ago, and became a key ingredient in reformulated gasoline that is sold in California. But recently new studies arose that showed that MTBE was far more toxic than previously imagined. Organizations such as oxybusters have formed around the country to eliminate the use of MTBE in gasoline and several states, including California have passed new laws to eventually outlaw MTBE.
              • F Offline
                F Offline
                fanaticrockford
                Q: How much toluene should I use per tank of gas?
                A: Octane ratings can be very easily calculated by simple averaging. For example, the tank of an Audi A4 1.8TQ is 15.6 gallons. Filling it with 14.6 gallons of 92 octane and 1 gallon of toluene (114 octane) will yield a fuel mix of:
                (14.6 * 92) + (1 * 114) / 15.6 = 93.4
                The Audi A4 1.8T is a good example of a car that has very high octane needs if it has been modified to produce more turbo boost. The base compression ratio of this car is a very high 9.5:1 and when an additional 1 bar (14.7 psi) of turbo boost is applied on top of it, the resulting effective compression ratio is way beyond what 92 or 93 octane fuel can ever hope to cope with. Most modified 1.8Ts running without octane enhancement are running with severely retarded ignition timing and boost.
                Q: Will toluene damage my engine or other parts of my car?
                A: A 5 or 10% increase in the aromatic content of gas will most likely be well within the refining specifications of gasoline defined by ASTM D4814, which specify an aromatic content of between 20% and 45%. What this means is that if the 92 octane gas that you started off with had an aromatic content of say 30% and you increased it by 10% to 40% you would still be left with a mix that meets the industry definition of gasoline. So the above question would amount to: "Will gasoline damage my engine or other parts of my car?"
                Even in the unlikely event that the 92 octane gas has a aromatic content of 45% the resulting mix would still be within the bounds of gasoline sold in other countries.
                Q: Isn't toluene an extremely toxic substance?
                A: The common perception of toluene's toxicity far exceeds reality. Fortunately there is an ample body of information available that specifically addresses this question. Toluene is more toxic than gasoline but it is certainly not agent orange or cyanide. See the Agency for Toxic Substances link below in the reference section.
                US Environmental Protection Agency Chemical Summary
                US Agency for Toxic Substances and Disease Registry (ATSDR)
                National priority list of toxic substances
                Note that the ATSDR also rates gasoline as a hazardous substance.
                Mobil's spec sheet for toluene even goes as far as saying that "Based on available toxicological information, it has been determined that this product poses no significant health risk when used and handled properly."
                Q: Isn't toluene an active ingredient of TNT (trinitrotoluene) and is thus deadly?
                A: In the same way that cotton wool is the base ingredient of nitrocellulose (guncotton) which in turn is the main ingredient in modern smokeless gunpowder. Using this reasoning one could conclude that cotton wool is a deadly substance. This question reflects a poor understanding of basic chemistry but unfortunately it has been asked often enough.
                Q: How much does toluene cost, and where can I buy some?
                A: $10/gallon in a one gallon can at a hardware store, about $6/gallon in a 5 gallon can from a chemical supply or paint store, or $3/gallon in a 55 gallon drum from a chemical supply warehouse.
                A2: Experience of Charlie Smith in 2002. Sherwin Williams paint stores have it for $5.00 in a gallon can. They can order it in a 5 gallon can at $4.00 / gallon. They can order 55 gallon drums for about the same cost per gallon, but you have to have a dock unloading facility to get the drum(s) off of the delivery truck.
                Q: Can I just dump in 100% toluene into the tank like the F1 racers? vroom vroom vroom
                A: First of all, the F1 racers did not use 100% toluene, but 84%. The other 16% in their brew is n-heptane, which has an octane rating of zero. The reason for this strange combination is because the F1 rocket fuel was limited to the rules to being of 102 RON octane. The n-heptane is "filler" to make the fuel comply with the rules.
                Because toluene is such an effective anti knock fuel it also means that it is more difficult to ignite at low temperatures. The Formula 1 cars that ran on 84% toluene needed to have hot radiator air diverted to heat its fuel tank to 70C to assist its vaporization. Thus too strong a concentration of toluene will lead to poor cold start and running characteristics. I recommend that the concentration of toluene used to not exceed what the engine is capable of utilizing. i.e. Experiment with small increases in concentration until you can no longer detect an improvement.
                Q: Why not simply use racing gasoline or aviation fuel?
                A1: Most types of aviation fuel have very high lead content, which would rule out cars equipped with catalytic converters. Most piston engined aircraft burn leaded fuel. Also aviation fuel has a very different hydrocarbon mix to optimize volatility properties at high altitude.
                A2: Racing gasoline could be a much more convenient way to run high octane fuel compared to having to constantly mix in toluene with each fill up. There are, however a few caveats:
                You don't know for sure if you are really getting what is being advertised. You should find out if the fuel inspectors verify the actual octane of the racing gasoline in addition to ordinary gasoline. If you paid $3/gallon and only got 94 or 95 octane instead of 100 octane you may conclude erroneously that your car does not benefit from octane boosting.
                You don't know what octane boosters are used in the racing gasoline. The worst case scenario is buying leaded racing gasoline without knowing it. Unleaded racing gasoline may still contain damaging octane boosters like MMT or methanol. A very high alcohol content will lead to fuel line erosion, accelerated fuel pump wear, very poor fuel economy and possibly lower performance, as alcohols have a less impressive MON rating than aromatics.
                It takes smaller quantities of toluene to achieve the same octane boost compared to 100 octane racing gas. I have not seen unleaded racing gas for sale that exceeds the octane rating of toluene.
                Since toluene is not officially sold as a fuel, gas taxes do not apply. Also racing gasoline tend to have higher markups being of interest to the performance minded enthusiast and thus is very likely to be more expensive to buy and use long term than toluene, which is typically used in more mundane applications like paint thinner.
                    Sweet FAQ ^bump^
                    • raviR Offline
                      raviR Offline
                      ravi
                      Ya, I am very familiar with Toluene and it's properties... I did a bunch of research on it before using it (probably 15 times).
                      I think the $6 pump is the way to go, atleast for now.
                      2008 Audi A4
                      2000 Audi S4
                      - Sold
                      12.4@116
                        yeah...still cheaper than toluene
                          I agree. I think that taking the risk of mixing your own race gas in an audi is just asking for trouble...expensive trouble.
                          • RaiderR Offline
                            RaiderR Offline
                            Raider
                            so Brady's Service has 100 octane at the pump?
                            POWERD BY
                              i found a while back, that xylene, toluene, and any form of alcohol would work well as an alternative for higher octane (do not read as higher chemical energy value, as we should all know by now that alcohol does not have a higher value), but they tend to corode plastic and rubber in higher concentrations. by this reasoning, one should not use more than 30% or so of any of the above unless they've made proper changes to the fuel systen
                              • DanglerD Offline
                                DanglerD Offline
                                Dangler
                                The dealer for Sunoco 104 unleaded is Curt with Curtis Oil. He sells it to Perf Auto and to Rick at Auto Specialties. If you want it in small quantities (less than a 15 gal barrel), call Rick, else call Curt.
                                PM me I have their numbers
                                  Raider wrote:
                                  so Brady's Service has 100 octane at the pump?yes, they have a really shitty old pump that has 100octane unleaded for 5.99 a gallon or leaded race gas for 4.99 a gallon
                                  • ErikE Offline
                                    ErikE Offline
                                    Erik
                                    Does anyone know where I can find like 94 octane around? The best I've seen at the pumps is 92.
                                    They call me, old man...
                                      bah, you don't need 94 octane... silly stock motor guys....
                                      i've heard rumor of 93, but i haven't bothered looking, 92 suits my needs at this point. besides, if nick (tufte and thompson), dave, matt, and nate can make the kind of power (or close to it) that their cars are capable of with 92, then i can be happy with it too.
                                      edit: sorry kevin ;), forgot you in the list
                                      • raviR Offline
                                        raviR Offline
                                        ravi
                                        I've gotta rant.
                                        So I go to Phillips 66 (Brady's Service) to get some 100oct. They wouldn't even sell it to me! The "mechanic" was trying to feed me shit about hardened seals, and how my engine would blow in my "little 6'er". It all started off with them telling me it was 100 LEADED, when it clearly says 100oct UNLEADED on the pump. After I snapped a pic of this on my phone and walk back to his desk, he tries to change his story. Damn, what a waste of a drive to Moorhead.
                                        When I tried to explain to him that my car is indeed performance oriented with a bi-turbo motor and numerous mods, including upgraded fueling parts from the Rs4 in Europe. I got a "OH, Europe" reply. He through in "you probably have 22lb injectors, blah". I know my injectors flow at 350cc / 4bar, but I'm not sure what that converts to in lb/hr. However, it's definately enough to run 100oct.
                                        I said, whatever I'll just go elsewhere. He replied with "too bad you can't find this anywhere else around here." I was pissed by now, and made a few smart ass comments (probably shouldn't have), and followed by telling him I could get Sunoco 104 at a couple different shops.
                                        Morale... Don't go to those guys, they are a-holes. :mad:
                                        2008 Audi A4
                                        2000 Audi S4
                                        - Sold
                                        12.4@116
                                          god too bad it wasnt the owner...hes a nice guy...lives down the street from me
                                          edit: did you get the guys name? maybe you could call and ask for the owner and tell him that...im sure he wouldnt like that too much
