  4. roll cage
roll cage
14 Posts 10 Posters 1.6k Views
    who in the FM area can build a roll cage?
      Laskie or however you spell it can.
        I think thats obvious....maybe i shouldve posted.. who in the fm area WILL build me a roll cage.
        And if you know of someone, or a company, i'll need more than a last name 🙂
        • drift86D Offline
          drift86D Offline
          drift86
          Shane laske is his name. Some one on here should have a way of getting ahold of him. I got the number but its his cell phone and I need to get an ok to give that out.
          AE86 project: sold
          93 r33 gts25t new project
          00 impreza obs
            sls will also do it
            • drift86D Offline
              drift86D Offline
              drift86
              Ok I just talked to him and he told me it is ok to post up info.
              Laske fabrication
              7012128812
              AE86 project: sold
              00 impreza obs
                thrash
                if you have a pretty common car, you should be able to find one pre-made (or 80% pre-made) and have it shipped here. Should save a lot of money. The ideal setup would be a weld-in unit where the tubes were cut, bent, and fisheyed for you already, and a competant welder assembles it in-car for you.
                The reason is that cage design is hard if you want to do it right. I'm not at all saying that it is beyond anyone here, just that the design and setup is going to be 99% of the time invested. The welding/install is the easy part. Someone that designs and sells pre-made cages or cage-kits for your car has amortized that design and tooling time across lots of cages, so it should save you some dough.
                I had a bolt-in half cage for my E30 BMW shipped to my residential address for around $600, IIRC.
                • drift86D Offline
                  drift86D Offline
                  drift86
                  Just a heads up on that thrash I was going to have laske do a cage in my 86 corolla and it was going to be around the same price for a scca legal cage with door bars. He designs and builds his own. He does everything from dirt track cars to welding up little holes in ic piping. He will do a great job and for a reasonable price. Definatly worth the money
                  AE86 project: sold
                  00 impreza obs
                    thanks for the info max.
                      if you get a prefab cage and need some minor welding done, I got a welder John.
                        Ive heard that some pre-fab cages fit well, but the S&W kit I got for my red car needed a lot of fitting to make it work. Custom is nice, Laske can make it fit nice and tight.
                        • Afsil80A Offline
                          Afsil80A Offline
                          Afsil80
                          ^ I've got a 10 pt S&W cage for my 240 and I can tell just looking at it that it will require some tweaking.
                          -Peter
                          1991 240SX
                          • b almerB Offline
                            b almerB Offline
                            b almer
                            i heard autopower cage are good
                            but dont know if they make it for your car
                            GROUND ASSAULT
                            99 pontiac grand am
                            86 mazda rx-7 gxl
                              Not for the 240...... LOLZ.
                              From what I have heard, do not buy anything more then the 4 point autopower,
