  4. busted a oil pressure fitting, now what?
17 Posts 6 Posters 774 Views
  • wa2fastcamaroW Offline
    wa2fastcamaro
    I was putting a new motor back in my truck last night, chevy 350 TBI. While connecting the harness up I found I had the wrong oil presure sender in the new motor, while trying to get the old sender out, I busted the brass 90 degree fitting uff flush with the block. Thinking no big deal of it, I tried to use a easy out on it and proceeded to bust that off flush with the block too. Now I got to extract that mess somehow but haven't the foggiest idea how. Anyone got any ideas? I got to get it out. And I am not too happy with pulling the new motor as it took 4 hours to get it back in and I was literally 20 minutes from starting it until this happened.
    Mike
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
    • darkelvisD Offline
      darkelvisD Offline
      darkelvis
      reverse drill bit style ez out?
        damn you broke an easy out in it? thast gonna be some difficult shit to drill through
          p.s. nice to see ya here elvis haha
            a drill bit would suck...
            easiest/best would be weld on the easy-out then use a vice grips to back it out.... more than likely will bring the broken fitting with it......just be careful where you are grounding
            just make a little nub on the easy-out you can get ahold of with the vice grip....... works 1000x's better and faster then reverse drill bits for broken off bolts i know that
            • XJHEADX Offline
              XJHEADX Offline
              Get some washers with the hole a little smaller than the brass fitting . Stack them one at a time and try to weld them to the easy out. Build them up high enough until you can get a vise-grip on them.
                thats a good idea^
                • gsrEKG Offline
                  gsrEKG Offline
                  gsrEK
                  weld a nut on and spin er out
                  2009 Yamaha Zuma 125, gas HOG
                  2008 Honda Fit daily
                  A s2k
                  1991 Honda civic DX Mint SOLD
                  1988 Mitsubishi Mighty max
                  > BlackEJ8;233529 wrote:
                    the obvious choice
                    • gsrEKG Offline
                      gsrEKG Offline
                      gsrEK
                      SPANISH-RICE;233371 wrote:
                      the obvious choice
                      next time u break something i wont give u any imput ha
                      A s2k
                        wont need it 😄
                        • gsrEKG Offline
                          gsrEKG Offline
                          gsrEK
                          shut it haha i will still help
                          A s2k
                            ya i bet
                            • gsrEKG Offline
                              gsrEKG Offline
                              gsrEK
                              SPANISH-RICE;233389 wrote:
                              ya i bet
                              wow ok
                              A s2k
                              • XJHEADX Offline
                                XJHEADX Offline
                                The nut may or may not work. It is harder to get tip down in there for good penetration and without melting the surrounding area. I always use washers, fill them in completely then stacked another one etc. until built up enough for the vise-grips.
                                  wa2fastcamaro
                                  I got it last night, I tried welding to the ez out and would not hold, must not have been enough material to weld to. I didn't want to do any drilling and risk metal shavings in the oil passages.
                                  What I ended up doing was using a punch and pounding the ez-out through the fitting till it fell in the block. Then I torched the fitting with the intake off and used another bigger ez-out and backed it out really nice.
                                  Getting the chunk of the old ez-out out was interesting though. I ended up modifying one of those telescoping magnets to fit through the oil sender hold and got the piece out.
                                  I was a happy guy last night, as I got the truck running and my $150 TBI 350 I baught is one hell of a nice motor, looked brand new in the lifter valley.
                                  Phone: 701-371-5615
                                    hell yea good to hear
