  4. Turbo Rebuild
Turbo Rebuild
17 Posts 8 Posters 1.4k Views
    gsrEK;233366 wrote:
    most likely have to send it off
    why do you say that?
    • gsrEKG Offline
      gsrEKG Offline
      gsrEK
      cuz no one in town can
      2009 Yamaha Zuma 125, gas HOG
      2008 Honda Fit daily
      A s2k
      1991 Honda civic DX Mint SOLD
      1988 Mitsubishi Mighty max
      > BlackEJ8;233529 wrote:
        some places can do minor rebuilds in town.
          and there still might not be anything wrong with it
            akielb
            The reason I'm looking around for a place to rebuild is because they sold the turbo as a "rebuildable core" mostly due to the not knowing the history on the unit. But for how clean it looks it might not have that many miles on it. They said it has no shaft play and spins freely, I think they were just covering themselves. I'm just trying to get info just in case.
              midland diesel can do minor rebuilds. talk to ka24blahblahblah about it
                The only way it would have to be sent off is if balancing needs to be done....
                and that is only would be required if something on the rotating assembly is replaced or you didn't keep track of how the compressor wheel was indexed to the turbine shaft when you took it apart....
                there is nothing to a journal bearing turbo.....
                just make sure you keep track of where the compressor wheel was indexed on the turbine shaft when you take it apart...... spec your turbine shaft journals..... install your new bearings, seals, ect.... then put it back together with the compressor wheel in the original position....
                Majestic Turbo.... is who i would send it off to if i had to... cheap, and a good job....
                To balance a rotating assembly they only charge something like $60... and i believe it is dynamic
                • BassplayerB Offline
                  BassplayerB Offline
                  Bassplayer
                  That thing looks to be in decent shape. I'd take it to Dave at Sports car engineering in Moorhead. He could rebuild an audi turbo in his sleep.
                  1995 GMC Sierra
                    Sometimes, its cheaper to buy a new one then to rebuild it.
                      Why would you waste money on a K03 btw?
