Fargostreet 1/4 Miles Times
00Ws6TransAm;234551 wrote:
Finally, [email protected] - 9/06/08nice work :icon_thumleft:
you are on a stock block even aren'tyou??, how much spray did it take to do that
impressive to say the least
zbrown;234580 wrote:
Bill, how did your tranny work today? is the brake and everything good to go now?? hahaIt worked too well, was blowing the tires off of the line on a few runs.. First pass of the day 10.18 @ 153. I think that was against 00Ws6. That was just with B.Controller to add 5 psi.
I turned on the timer for boost. Ran a 9.55 @150
Turned it up some more blew the tires off 1-2
Made an susp. change same tune then ran that 9.29I think if I can get the 60's in the 1.4X and fine tune the boost controller I should be able to see high 8's:ford:
zbrown;234581 wrote:
nice work :icon_thumleft:you are on a stock block even aren'tyou??, how much spray did it take to do that
Yea stock bottom end, 180 shot.
Thanks.
Finally, [email protected] - 9/06/08Nice to see that!!! What changes did you make or was it just weather?
Christian;234638 wrote:
Nice to see that!!! What changes did you make or was it just weather?Shiftkit was a big improvement, bumped up my rev limiter so i didnt hit it, track prep was good, weather was ideal, andy helped me tune it up better (more timing and a little bit less fuel. I used the same NOS jets as when i ran 11.002.
Christian;234832 wrote:
10.78 @ 125 9/7/08 93 MustangNice you went on sunday? HOwd it run? Nice on the 10.7!
Oh wow thats impressive esp without it running well!
Nice work. -
New best time!!!!!
13.73 @ 100.47 IDR 10/4/08
KA-T_240;239933 wrote:
New Best[email protected] with a 1.87 60ft.
I wonder whats happening to my MPH?
Traction will kill mph.
What was your 60' before??
