  3. Who was that?
  4. rolled subaru
rolled subaru
121 Posts 31 Posters 8.7k Views
  • mr.98gsxM
    mr.98gsxM
    mr.98gsx
    bubba;236133 wrote:
    That sounds like a downgrade on your part...
    yea but his eclipse would prolly be easier to sell considering not many ppl wanna buy a race car. lol
    And the car sounded fine when it was started, and aside from a little smoke comin out of the exhaust all looked normal. I don't know subies, but it sounded healthy. What could internally be wrong just by rolling it?
    • STi ScottS
      STi ScottS
      STi Scott
      zbrown;236243 wrote:
      couple summers ago I rolled a scraper on a 4:1 laying topsoil
      by the time i got to the rear engine and shut it off it had only ran for probably 10-15 secs. on its side
      ran fine for about a week after that... then you know how the rest of the story goes
      I talked to my friend who is a mechanic, and he said that most cars turn off automatically after being overturned. There is some kind of switch in them that cuts the fuel or something. I know Fords have an inertia switch that kills the fuel with any sort of impact, and according to him most cars have similar kill systems.
      • K
        K
        I would go talk to Elroy at Subaru over your friend. He is the one that gets paid the big $$$$ to work on subarus everyday. Probably is the one who put that motor in the car.
        • Gundar1G
          Gundar1G
          Gundar1
          Oh yeah, isnt that motor like a year old??
          EVO
          • K
            K
            motor in car has 8k on it.
            • STi ScottS
              STi ScottS
              STi Scott
              Good call for sure. If anyone would know he would. I'll definitely pay him a visit.
              • svxALS
                svxALS
                svxAL
                elroy is definitely a good mechanic he has done a lot of work on my red svx and has a really good reputation around town for knowing his shit
                94 Subaru SVX FWD
                subaru-svx.net
                1999 silverado
                • STi ScottS
                  STi ScottS
                  STi Scott
                  Talked to Elroy at Subaru today, and he said that all subaru's will automatically kill the fuel when they are overturned so the car would not have been running upside down. He said the only problem that could have occurred is oil getting into the cylinders and hydrolocking when the engine trys to start which could of course bend the connecting rods. However, since the car started no problem that obviously didn't happen. Therefore, coming from the expert, nothing is wrong with the engine.
                    • STi ScottS
                      STi ScottS
                      STi Scott
                      Well after doing some research I have decided the way to get the best results out of the swap is to actually go through the work of swapping the entire STi wiring harness and ecu. Without doing this the AVCS will not work, and this will cause worse gas mileage, rougher idle, more turbo lag, and a little less power overall. So AVCS is definitely a benefit, and you can only make it work if you swap the ecu or buy a standalone unit. Since I have the entire donor car, and all the electronics are in perfect working order it seems like that is the best way to go.
                      • SPANISH-RICES
                        SPANISH-RICES
                        Do it and let us know
                        • FG2F
                          FG2F
                          FG2
                          I guess I am confused....What other option were you considering?!?! You have a complete car, with complete harnesses, and complete hardware....
                          It is impossible to say there is nothing wrong with a motor that was in a car that rolled. Internally, it seems everything is ok (which was assumed after hearing it was driven after the accident), but don't forget the force that is applied to a car when it is rolled.... There can be physical damage to the transmission housing/block/heads that aren't causing driveability issues RIGHT NOW, but that doesn't mean there is 'nothing wrong with the engine'. Be smart, and look over everything VERY well and disassemble whatever you are comfortable with to make sure you aren't creating further headaches for yourself down the road.
                          My $.02
                          • SPANISH-RICES
                            SPANISH-RICES
                            Sti atv
                            • STi ScottS
                              STi ScottS
                              STi Scott
                              According to the forums I have been reading I have 2 other options... 1. Use the WRX ecu which requires a tune obviously and some other things but the AVCS won't work then or 2. buy a standaloneunit which I don't really want to do either.
                              I agree though, I do plan to look over the engine/tranny/etc. to see if anything is wrong. I worded that wrong though earlier. Basically what I was trying to say was that Elroy was very confident that nothing was wrong. Hopefully he is right lol
                              • SPANISH-RICES
                                SPANISH-RICES
                                if you have the sti ecu why would you use a wrx ecu?
                                utec ftw
                                • STi ScottS
                                  STi ScottS
                                  STi Scott
                                  utec ftw
                                  Well the whole point behind using the wrx ecu is so that you don't have to swap in the entire sti wiring harness. If you swap the sti ecu you also have to swap the wiring harness.
                                  • SPANISH-RICES
                                    SPANISH-RICES
                                    Man up, swap it 🙂
                                    • STi ScottS
                                      STi ScottS
                                      STi Scott
                                      SPANISH-RICE;238193 wrote:
                                      Man up, swap it 🙂
                                      Haha, plannin on it.
                                        • STi ScottS
                                          STi ScottS
                                          STi Scott
