  4. Anyone have parts/help for building fish house?
8 Posts 7 Posters 1.6k Views
  • FG2F
    FG2F
    FG2
    I am in the beginning process of figuring out how to build my fish house. I currently have nothing, and have done a bit of research on frames/drop axles/crank down frame, and honestly I am looking for the cheapest vs. most reliable option. Anybody have a friend/father/neighbor that is selling either a REALLY cheap fish house (that I would tear down and pretty much use the frame for), or have a frame that could be used for a fish house?
    Thanks!
    Jason
    • bubbaB
      bubbaB
      We had a guy that had a display model at our shop idk if its still there or not... i can get his info for u or something...
      • MisterCMKM
        MisterCMKM
        2 of my friends are building at the moment. One started with an ice castle with no interior and the other started with a pop up trailer frame.
        thrash;315544 wrote:
        Ford is back :)
        • DaveHD
          DaveHD
          This sucks, I ended up throwing away my Dad's portable last year after I couldn't find anyone that wanted it.
            Thanks!
            Jason
            If you need a hand with one, I can help Jason....built a good number of them over the years.
            • FG2F
              FG2F
              FG2
              You cannot help, you require too many dorito's :icon_rendeer:
              I will hit you up once I get the frame figured out. I want crank up/down wheels, but judging from the frame cost from those, I will have to stick with something A LOT less expensive... Travis (gsrEK) has a fish house sitting in a field that I am gonna check out strictly for a frame. (hurry up on the pictures kind sir)
              I would like to make it something pretty nice inside, and my sisters fiancee is great with a hammer...
              I also would like to get ahold of a wood burning stove (very small) that I can use as a heat source.
              • iluvracingI
                iluvracingI
                iluvracing
                my old man just built one out of a pop up camper frame. it's pretty much done and pretty much going to be bad ass! Also he has ALOT less into his (with powdercoating frame) than an ice castle would run. very inexpensive way to go and you can basically do anything you want. I would for sure go with a pop up camper if you can find one cheap. We had one so that was a plus. good luck.
                96 sunfire se pos!
                2002 v-star 1100-For Sale. (NEED GONE!)
                91 Eagle Talon (hopefully running for auto-x)
                97 F 150
                • capitljC
                  capitljC
                  capitlj
                  Propane heat is a better way to go the wood stove will roast you out in no time flat. My brother built one using some waste sheets of some material that was like two sheets of aluminum sandwiching some heavy foam insulation. Works great.
                  Mitch Hedberg wrote:
                  2004 Impala LS 3.8
