boosted ek partout
so if there is front end damage, there rises the possibility of you front mount and/or piping being damaged.
No body is going to buy a wrecked civic for 15k, people have a hard enought time selling k-swap civics with no damage for less than that
no_slow_clap;238837 wrote:
so if there is front end damage, there rises the possibility of you front mount and/or piping being damaged.No body is going to buy a wrecked civic for 15k, people have a hard enought time selling k-swap civics with no damage for less than that
the piping or front mount are fine thats the first think i looked at.
and i'm not askin 15k for it anymore i was askin 15k before yesterday when there was no damage!!!!!!!!!!!!
1990TSI;238845 wrote:
the piping or front mount are fine thats the first think i looked at.and i'm not askin 15k for it anymore i was askin 15k before yesterday when there was no damage!!!!!!!!!!!!
OOOOO. ok, well in that case....gimme some info on your turbo. what were the spool characteristics with your setup and where did it peak?
no_slow_clap;238846 wrote:
OOOOO. ok, well in that case....gimme some info on your turbo. what were the spool characteristics with your setup and where did it peak?it starting makin boost at 6k and made real power at 7k the turbo is good for just about 800hp
i was only run 14psi because my boost controler was fucked up so i'm onyl runnin off of my wastegate spring when i got it tuned
I still need a 3bar map. Lmk i need just the sensor
I want the map sensor. How much without the pigtail
So youd take 30 then?
Idk man they go for 60 brand new with a pigtail. Id like to buy it but i dont really wanna pay 50 for it. Can you work with me on it a little?
