  4. Looks like time for a rebuild
14 Posts 9 Posters 1.8k Views
  • fdfreakF Offline
    fdfreakF Offline
    fdfreak
    zbrown;234736 wrote:
    I was scared by the title and thought for sure you had torn up your new housings...... so i am glad to hear you didn't
    coolant seals are nothing....just make sure to double check your irons to make sure they didn't warp on ya
    You said it is getting hard to start though..... so you are loosing compression somewhere, and i highly doubt you are loosing much through the coolant seals......... so hopefully something isn't chewed up inside, and maybe just some cracked corner seals
    good luck though 🙂
    I think the reason for the hard start is the spark plugs. With the 850 primarys i am running pretty rich and so I am sure that my plugs are fouled out being I havent changed them since May. I started it tonight for about a minute or so then it died. I then tried starting it again but it wouldnt turn over. Who knows! ill look at it when I have more time.
    12.645@118mph 12.6psi
      [I]<u>should of had a</u>[/I]
      • G Offline
        G Offline
        generation_xxx
        good luck on the rebuild, being a rx7 owner at one time i know the heartbreak the rotary can bring. but stick with them, there worth it
          AHAHAHAHAHAHAHA:icon_cheers:
          • CRX_CivicC Offline
            CRX_CivicC Offline
            CRX_Civic
            i think my 13b needs a overhaul also, i heard there pretty easy to do tho,
            • ErikE Offline
              ErikE Offline
              Erik
              Sounds like the perfect thing to keep you busy over the winter. Go for it.
              They call me, old man...
                well good luck with it man. how many miles on the engine right now?
                • fdfreakF Offline
                  fdfreakF Offline
                  fdfreak
                  GOOD NEWS! only need to replace a few orings and 1 gasket. it will cost me less than $300.
                    good to hear man.
                    • SlowicaS Offline
                      SlowicaS Offline
                      Slowica
                      jons 13b lost all compression on the rear rotor a week or so ago. blowing seals is the cool thing to do lol
                      • fdfreakF Offline
                        fdfreakF Offline
                        fdfreak
                        cool, but expensive!
