  4. issues boosting
issues boosting
42 Posts 10 Posters 2.3k Views
  • 9 Offline
    9 Offline
    92TSIpos
    -GSX-Falcon wrote:
    Im assuming hes making something so he can pressurize the system and locate where the leak is coming from. It usually is the piping but it may be something he cant see/tighten. Like a tiny hole in a lower pipe or something.
    thanks alot for clearing that up for me, i wasnt sure if he knew what i meant by "building something".
      I knew what what you meant, but it seems like a waste of time to do something like that right off the bat... which it sounded like you were going to do... if all it was was a loose clamp, loose bov or something
      • 9 Offline
        9 Offline
        92TSIpos
        Yeah i guess that would suck. I will prolly check everything over, and if anything else go to plan B.
        • 9 Offline
          9 Offline
          92TSIpos
          right now im not even sure if its a boost leak. I should say screw it and bring it to kevin and have him check it out if i cant find anything.
            lol good one jim!!
            Kevin
              your welcome lol
              • 9 Offline
                9 Offline
                92TSIpos
                if what i described is not a boost leak than what else could it be?
                  the fact that you let max touch your car and help you do stuff to it might be the problem. j/k
                    have you gotten a second opinion on how the car feels under boost? it might not be anything because you're so used to how it feels. as far as the sputtering... without konwing anything else about the problem, i'm going to guess that you're getting too much fuel somewhere
                      yeah the car is known to run really rich too...i was gonna chime in but i didnt have too much other info
                        max is a good guy!!
                        Kevin
                        sls
                          I've driven the car. It's not the feeling of a normal DSM. the turbo spools nice til 11 or 12 lb.s and then sputters really bad. could it possibly be the turbo?
                          • -GSX-Falcon- Offline
                            -GSX-Falcon
                            If its boosting up to 12 then its prolly not the turbo, but it could be. Does it feel like the engine just shuts down...then it comes back...then shuts down again? If it does thats probably fuel cut. Cold can effect that, but so can a boost leak.
                            Also Jim awhile back i think you said something about running rich causing fuel cut. Maybe you didint....but I was under the impression Fuel Cut was the ECU seeing too much air flow through the MAS.
                            92 GSX Automatic -Manual Cams, Injectors, ECU -Big 16g -Turboback Exh -Ported Evo Manifold -Ported 2g o2 -MBC -JDM 4g63 -Walbro 190 -3" Intake
                            • 9 Offline
                              9 Offline
                              92TSIpos
                              I have a 2g mas 550cc injectors, afcII, and afpr, i tried screwing with the afc a little bit, thought it might have been rich. I also have a narrow band air/fuel guage that i kinda monitor, and it seems that it is tuned pretty good as far as air fuel goes, but i think those things suck, I should get an lm1 and be done with it.
                                lm1?
                                ok, let's get this all on the table... what's done to the car?
                                • 9 Offline
                                  9 Offline
                                  92TSIpos
                                  I have a built bottom end with 1g big rods 2g pistons, .2 over bore, hks 272 cams
                                  afcII, 550cc injectors, 14b turbo, sls intercooler piping, intake, 2g mas, k&n fipk, boost controller (spelling?), 2g exhuast manifold, full 3" exhuast with o2 eliminator, 255lph hp fuel pump, afpr, thats all i can think of right now. I think i found one of the boost leaks but it still sputters a little bit, and now I get bad boost spikes. I have it set at 10 pounds and it spikes to 20 pounds. got any ideas?
                                    do you think that one of your boost leaks is coming from the boost controller?
                                      i had the same problem with my old 7 bolt motor...and it got really screwed so i got a 6 bolt and it did almost the same thing...it would sputter...then take off and then boost up to 20+psi
                                      • 9 Offline
                                        9 Offline
                                        92TSIpos
                                        Yeah I did make some thing to check for boost leaks and the boost controller was one of them, then I had one between the turbo and j pipe, then I had one on the intake manifold. I fixed them all, the boost controller still leaks a little but at 50 psi, so it shouldnt be an issue.
                                        • 9 Offline
                                          9 Offline
                                          92TSIpos
                                          did you ever fix it, or is it still the same?
