  4. Interior light wont shut off.
22 Posts 9 Posters 1.2k Views
  • jct_4628J Offline
    jct_4628J Offline
    jct_4628
    im sure you could find someone else with ur car with a manual or search long enough online and find one. Maybe the dealership would have access to one??
    Jason
    -06 WRX
    -95 CBR 600F3
    701-541-2568
      try just bending the metal part around the white plastice piece up so the door actually pushes the plastic piece in when its closed.
        I pulled out the fuse and the light went out mission accomplished.
          thanks mwc1! haha
            mwc1 wrote:
            thanks mwc1! haha
            Yeah but just now when I was driving it around at just about every stop the car would shut off and taking out that fuse disabled the radio.
              Chris get ahold of me tomorrow at work and I'll see if I can help you out.
                OK will do.
                  dynotune wrote:
                  Door ajar switch open circuit. Remove switch on drivers side, ground wire and if light goes off, that switch is bad. If not check other doors including hatch.
                  what was wrong with this help? this is the correct way to fix it!
                  • 9 Offline
                    9 Offline
                    92TSIpos
                    if you didnt fix it try putting a small tack weld where the light switch connects in the door jam. i did that on my girlfriends car because the door jam was dented in.
                    just my two cents.
                      I had the same problem with both of my DSM's. If I can see it, I'll probably be able to figure it out.
                        Pull the fuse... Mid West Customs is the best shop ever!
                        lol just messin with ya.
                          Yeah after taking out that door switch I took it out on the freeway and played a little bit but once I stopped the idle just went back to normal. Sweet!!!
                          I think I owe you a six pack or something.
                            i never even knew it was a shop haha...but pulling the fuse would solve the problem
                            • My NOvaM Offline
                              My NOvaM Offline
                              My NOva
                              it didnt cause"Yeah but just now when I was driving it around at just about every stop the car would shut off and taking out that fuse disabled the radio."
                              hadhappend
                              Hey Tina come get some hamm
                                I was thinking that but you never know.
