  3. Track Talk
  4. My air cooled crank
My air cooled crank
68 Posts 34 Posters 10.0k Views
    Got the turbo and header off so far, got two holes in the block and the piece in between isn't held on by much. Looks like #3 failed, I can see the main part of the rod in the oil pan, so either the wrist pin failed or the rod bolts failed. My guess would be wrist pin.
    You can see the rod sitting in the oil pan in this pic, the wrist pin hole in the rod is there, but wrist pin is nowhere to be seen. Thats a fairly big piece of aluminum behind the rod, I guess thats part of the piston.
    • 3_Series3 Offline
      3_Series3 Offline
      3_Series
      Ouch!
      2002 Subaru Legacy
      1993 BMW 325i (sold)
        wow, i cant wait to see it all apart
          Damn!!!
            that sucks!
            • civic91C Offline
              civic91C Offline
              civic91
              wow, shitty.
              04 Toyota Celica Gts
              • 94civicex9 Offline
                94civicex9 Offline
                94civicex
                go big or go home i guess
                Playtime Performance
                2005 Yamaha R1 [email protected]
                2009 Zuma 125
                1995 Honda Civic DX
                  Wow more carnage pics!
                    thats awesome
                    • SlowicaS Offline
                      SlowicaS Offline
                      Slowica
                      just throw some JB weld over the holes. surprised you didn't blow the welds on the intake with all that NOS. That really does suck though
                        It was just a 150 shot, weak sauce.
                          Was that a stock shortblock?
                            Nope, it had stock crank and mains, but had carrillo's and JE's. Got the head off tonite, still not exactly sure what caused the failure. #3 piston is stuck in the cylinder at an angle. I got the crank rotated a bit and got the rod out through the side of the block.
                              Gonna need a dingle ball hone and 1 new rod and piston, should be good to go!
                              Looks like you need to go with the billet rods and a larger pin like matt has for next year, that thing should take a 300shot, 150s are for sissys
                                ouch, Carnage!!!
                                • GnArKiLlG Offline
                                  GnArKiLlG Offline
                                  GnArKiLl
                                  and a bucket of bondo to fix the hole in the block. then your set!
                                  1976 Chevy K5- lifted beater
                                    Vtec must have engaged pretty hard.
                                    • ruthless351R Offline
                                      ruthless351
                                      Yup! Thats it! Case closed........ :icon_geek:
                                      • Sweet-WRX-LovinS Offline
                                        Sweet-WRX-Lovin
                                        Wow messy one. When did this happen Dave?
                                        One time...
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          Rod looks like it got hot..
