  3. Run Your Mouth
  4. ms paint skillz
ms paint skillz
445 Posts 41 Posters 45.7k Views
  • K
    K
    LOL!
    Just so you know.... There may be a ca in my shop this spring.....
    • Afsil80A
      Afsil80A
      Afsil80
      As long as it's not an SR20...
      -Peter
      1991 240SX
      • ParkerP
        ParkerP
        zbrown;241848 wrote:
        nothing in it at the moment
        it never had anything anyway :rolleyes:
        weak
        BlueSRT0483;244555 wrote:
        Trafik Jamz;260984 wrote:
        You are right Parker.
        • zbrownZ
          zbrownZ
          weak
          anything is better than a leaky, seepy SBC
          • ParkerP
            ParkerP
            last time i checked.... mine dosen't leak.... just as clean as it was at the car show...
            try again
            • MisterCMKM
              MisterCMKM
              try again
              It also has just as many miles on it as at the car show. 😄
              thrash;315544 wrote:
              Ford is back :)
              • zbrownZ
                zbrownZ
                ummm.... it has to be driven to show 95% of the leaks....
                report back when atleast 5 heat cycles are accomplished
                • MisterCMKM
                  MisterCMKM
                  repost
                  See my post above
                  Ford is back :)
                  • ParkerP
                    ParkerP
                    dont you have a tranny to fix?
                    • ParkerP
                      ParkerP
                      crankcase evac system pwns you
                      gtfo
                      • MisterCMKM
                        MisterCMKM
                        Don't you have a bed side....
                        Don't start this :lol:
                        Ford is back :)
                        • zbrownZ
                          zbrownZ
                          MisterCMK;241865 wrote:
                          repost
                          See my post above
                          I was typing as you posted............... goddamn.... if you dont have something nice to say dont say anything at all
                          O-rings >>> an EVAC system used as a bandaid
                          • ParkerP
                            ParkerP
                            my truck moves... how about yours?
                            • ParkerP
                              ParkerP
                              yeah your right..... o rings will fix the positive crankcase pressure and give my cyl rings a total seal.... good job zac.... you know it all... i used it as a bandaid on a brand new motor....
                              • MisterCMKM
                                MisterCMKM
                                lulz, at least mine isn't a mall crawler, Mr. Mud Terrain tires but yet never drives through mud
                                Ford is back :)
                                • MisterCMKM
                                  MisterCMKM
                                  a SBC with rings that don't seal? Whodathunkit?
                                  Ford is back :)
                                  • ParkerP
                                    ParkerP
                                    from what i remember it wont be too long before you will be able to flinstone yours..... fred
                                    • MisterCMKM
                                      MisterCMKM
                                      Shouldn't you be looking into an opening at the dealership to have the rear end rebuilt? Should I start looking for a crate motor now or after you drop the valve?
                                      Ford is back :)
                                      • ParkerP
                                        ParkerP
                                        maybe you should rebuild it for me.... oh wait it seems you have to do that twice too... good job... sorta like your valve body... but that will be three times....
                                        • zbrownZ
                                          zbrownZ
                                          I call BS on no leaks....EVAC or not
                                          I could have inspected for leaks, but you were to big of a dick head, and stood me up............../story
