  3. Run Your Mouth
  4. OBAMA is a socialist!!!!
144 Posts 25 Posters 13.9k Views
  • BlueSRT0483B
    BlueSRT0483B
    BlueSRT0483
    tjamz;244147 wrote:
    They've only been wrong 1 time that I'm aware of....and that was when a newspaper mistakenly said that someone else won the election
    HAHA -- Irony -- There's a newspaper that has already published an Obama win.. Since they only publish like twice a month or so (IIRC) they published Obama as the winner..
    Google it for more info., but it was out there.. On CNN not too long ago.
    Could be another Dewey/Truman result HAHA
    2004 Dodge SRT-4
    ...Formerly "A853"...
    • MisterCMKM
      MisterCMKM
      http://politicalticker.blogs.cnn.com/2008/10/27/obama-wins-newspaper-declares/
      thrash;315544 wrote:
      Ford is back :)
      • MisterCMKM
        MisterCMKM
        tjamz;244157 wrote:
        I think it is funny the other way around that I can debate successfully a message board full of conservatives that somehow think the world would be better with zero taxes and zero social programs.
        Chuck, you are a conservative.
        Ford is back :)
        • 24valvenotak2
          24valvenotak2
          Im voting for Obama in hopes that parker has to pay more taxes next year.
          63vette;288530 wrote:
          • ParkerP
            ParkerP
            thank you
            BlueSRT0483;244555 wrote:
            Trafik Jamz;260984 wrote:
            You are right Parker.
              Shh....don't go wrecking my image....
              • wesholeW
                wesholeW
                Im writing Bryce in for president.
                • DaveHD
                  DaveHD
                  Back on topic a bit, the reason people are thinking Obama is a socialist isn't because of the numbers he's claiming in his tax plan, it's because of what he's said (spreading the wealth, etc). If he was given free reign of the tax plan what do you think he would set up? When Reagan was president he was only able to lower the tax rates a certain amount, but if he had free reign over it what do you think he would have done? Huge changes in our system are not possible due to the checks and balances, the problem is that things keep creeping toward socialism slowly, and before you know it there we are.....
                  • zbrownZ
                    zbrownZ
                    sure.....
                    • StangerBanger96S
                      StangerBanger96S
                      StangerBanger96
                      Except under Obama's tax plans, he (last I heard) was going to allow the current tax cuts to expire, reverting back to tax brackets from the year 2000. Since he's not actually CHANGING anything himself by signing off on something, he doesn't consider this a tax increase. In fact, a single person earning $50,000 a year will end up paying ~$1,000 more annually in taxes starting in 2010 under his plan. Let me see if I can go find the article again...
                      Also you guys are throwing out the 250K number, haven't you heard that there is speculation that the bracket might be down to 150K now?
                      Some of you also seem to conveinently forget that democrats are generally pro union, which in large part is behind the failing of the airline and auto industires. The idea behind lowering taxes on corporations may seem retarded at face value but when you look at the goal of it you'd see how smart it is. Right now it is cheaper for a company to build it's next plant overseas because profits made overseas are NOT TAXED AT ALL BY US and taxed at a much lower rate by the country they are located. If we closed this tax code loophole AND lowered our taxes stateside, there would be a LARGE incentive for companies to build their next plant right here in the good ol US of A. Unfortunately every time something like this is considered, dem's cry OH WHY LOWER TAXES ON CORPORATIONS!?!?!? Now, lowering taxes on the corporations alone won't do nearly as much as lowering taxes on them AND starting to tax their overseas profits. This would create more jobs in the country and (feasibly) bring over $500 Billion back into the country as well. Doesn't sound so bad after all now does it?
                        People making less than $250,000 will not see their taxes increase, and people making less than $200,000 will receive some type of tax cut. Those in the $200,000 to $250,000 range will see zero change.
                        Per the Tax Policy Center, here is how Obama's tax plan breaks down for individuals:
                        $0-$18,891 = $567 tax cut
                        $18,982-$37,595 = $892 tax cut
                        $37,596-$66,354 = $1,118 tax cut
                        $66,355-$111,645 = $1,264 tax cut
                        $111,646-$160,972 = $2,135 tax cut
                        $160,973-$226,918 = $2,796 tax cut
                        $226,919-$603,402 = $121 tax increase
                        $603,403-$2.87 million = $93,709 tax increase
                        $2.87 million-plus = $542,882 tax increase
                        What I have highlighted in red up above is pretty much what I've been saying all along.
                        I'm pro-workers rights (40 hour work weeks, etc...) and I think that although unions provide a lot of benefits for the workers, it also sets up a line of worker responsibility and a solid course of corrective action that in some cases makes it easier to terminate an employee than in non-union environments...IOW if the guy is a fuck up, write his ass up on 3 legit problems and terminate him.
                        • MisterCMKM
                          MisterCMKM
                          I hope you cite your source on that... 😄
                          Ford is back :)
                            source= fat kid w/ fro
                            • StangerBanger96S
                              StangerBanger96S
                              StangerBanger96
                              http://www.americanthinker.com/2008/10/senator_obamas_four_tax_increa.html
                              Here is the article I read yesterday...take it for what it's worth...
                              I've worked as the state level media and strategy director on three Presidential election campaigns -- I know how "promises" work -- so I analyzed Senator Obama's promises by looking for loopholes.
                              The first loophole was easy to find: Senator Obama doesn't "count" allowing the Bush tax cuts to lapse as a tax increase. Unless the cuts are re-enacted, rates will automatically return to the 2000 level. Senator Obama claims that letting a tax cut lapse -- allowing the rates to return to a higher levels -- is not actually a "tax increase." It's just the lapsing of a tax cut.
                              See the difference?
                              Neither do I.
                              When those cuts lapse, my taxes are going up -- a lot -- but by parsing words, Senator Obama justifies his claim that he won't actively raise taxes on 95 percent of working Americans, even while he's passively allowing tax rates to go up for 100% of Americans who actually pay Federal income taxes.
                              Making this personal, my Federal Income Tax will increase by $3,824 when those tax cuts lapse. That not-insignificant sum would cover a couple of house payments or help my two boys through another month or two of college.
                              No matter what Senator Obama calls it, requiring us to pay more taxes amounts to a tax increase. This got me wondering what other Americans will have to pay when the tax cuts lapse.
                              For a married family, filing jointly and earning $75,000 a year, this increase will be $3,074. For those making just $50,000, this increase will be $1,512. Despite Senator Obama's claim, even struggling American families making just $25,000 a year will see a tax increase -- they'll pay $715 more in 2010 than they did in 2007. Across the board, when the tax cuts lapse, working Americans will see significant increases in their taxes, even if their household income is as low as $25,000. See the tables at the end of this article.
                              Check this for yourself. Go to http://www.irs.gov/formspubs/ and pull up the 1040 instructions for 2000 and 2007 and go to the tax tables. Based on your 2007 income, check your taxes rates for 2000 and 2007, and apply them to your taxable income for 2007. In 2000 -- Senator Obama's benchmark year -- you would have paid significantly more taxes for the income you earned in 2007. The Bush Tax Cuts, which Senator Obama has said he will allow to lapse, saved you money, and without those cuts, your taxes will go back up to the 2000 level. Senator Obama doesn't call it a "tax increase," but your taxes under "President" Obama will increase -- significantly.
                              • kylushK
                                kylushK
                                kylush
                                1998 Z28 Camaro
                                  He has only stated that he will allow the taxes to reset on those above 250,000, those under that amount would stay the same AND have new tax cuts for those below $250,000 (actually, below $200,000...the $200,000 to $250,000 stay the same).
                                    http://taxcut.barackobama.com/ is his calculator...if the plans go through.
                                    I still contend that if you tax the middle class less, it will improve overall spending, thereby creating demand and ultimately more jobs.
                                      and a big thank you to google for helping me find this link as well.
                                      http://www.barackobama.com/pdf/taxes/Factsheet_Tax_Plan_FINAL.pdf
                                      • wesholeW
                                        wesholeW
                                        Chucks on a roll fellas. LOOK OUT!!! I love what I started. My lil thread has blossomed.
                                        Oh BTW. Obama is still a Socialist. A Nazi too.
                                        • T
                                          T
                                          thrash
                                          People (especially Jim, who is smart enough to know better) shouldn't confuse socialism and communism. Most european nations are "socialist" in the sense that the needs of society (defined by the government) are prioritized over the needs and rights of individuals.
                                          Socialism doesn't imply or require collective ownership of capital & labor, doesn't imply or require the government to set wages, etc.
                                          Socialist nations tend to feature very high taxes, very heavy regulation, and heavy redistributionist policies.
                                          There is no credible argument that Obama doesn't plan to take us further towards the socio-economic style of european socialism. It is NOT UP FOR DEBATE that he thinks it is appropriate to take more money from the wealthy to pay for services, programs, and outright handouts for the less wealthy. He wants this in the name of "social justice" and for "the good of society". He feels that the good of society is more important than the rights of a specific individual.
                                          Again, this is not up for debate. And this is essentially the definition of socialism -- prioritizing society over the individual.
                                          Furthermore, Obama is NOT someone who is satisfied with the US constitution. You can find his 2001 speech on civil rights, where he laments that the Constituion is a negative liberties document. He complains that the civil rights movement didn't do enough to transform the role of government in the US into a "equality of outcome" and "social justice" instrument.
                                          Everyone between FDR and Reagan, and everyone after Reagan, has allowed for creeping progress of the progressive/socialist agenda in the US. That doesn't mean that there aren't different Degrees of progress (well, regression IMO).
                                          For anyone that is on the fence about this or doesn't understand why smart people are so afraid the changes Obama hopes to bring, I can chat with you in person or PM you or whatever. I can also loan you my personal copies of "Free to Choose, "The Road to Serfdom", or "Capitalism and Freedom" -- books which will help you understand why what Obama wants, and why his general worldview -- is so dangerous to our prosperity and ultimately our freedom.
                                          It is my opinion that Obama is the most authoritarian-socialist leaning candidate for president we have ever had. The nastiest part about it is that he seems to be happy to ignore or work outside the law and even his own promises to acheive his goals. That concerns me a lot.
