  2. Local Shops and Businesses
  3. Boostwerx
  4. 1000cc injector blowout sale
Scheduled Pinned Locked Moved Boostwerx
12 Posts 6 Posters 6.7k Views
    I have a couple sets of 1000cc injectors in stock, brand new in the box. There are two sets of 4, both sets are flowed together so they could be sold as a set of 8 also.
    Set of (4) 1000cc - $212.00
    Set of (8) 1000cc - $424.00
      low imp. i am guessing?
        Yep, low impedance.
          What kind?? And what style (will they fit a honda)??
            aliengotpsi
            Will they fit evo8? I'll take them if they do and if I can make my car run with stock ecu.. I'll make a few calls..
            Kevin Smith
            Straightlinedetailing.com
              They are domestic style. I can spin em on a lathe if you need em to fit mitsu. I'm not sure what the Honda ones look like.
                  might be interested in 4 of them if they will fit a subaru.
                    I think your stock injectors are side feed? Not positive....
                      STi is side feed (IIRC), WRX is top feed.
                        I looked online a little and I'm pretty sure these could work. Do you have any stockers laying around that I could look at? You'd have to splice on new electrical connectors, because these use the rectangular injector clips, I have the clips in stock too.
                        • fdfreakF Offline
                          fdfreakF Offline
                          fdfreak
                          if I ever run duel walbros and tune at 18psi ill probably run these but im running too rich with my 850cc's as it is. good price though!
                          12.645@118mph 12.6psi
