  4. Anodizing
Anodizing
23 Posts 12 Posters 1.0k Views
    Size capabilities just depends on how large of containers we decide to use. If anything i can buld my own containers to do larger items but it's just gonna take that much more dye to do so if its an odd ball color price will have to be inflated to compensate. Most stocked color will be black as i do all of our gauge bezels in black. Like i said after we get everything setup and get everything rolling i'll be more apt to give quotes but i dont wanna jump in head first and underquote on something thats gonna take twice as lon as anticipated. Also as far as i know we will be the only place in town w/ capabilities of anodizing :-).
      seanjohn
      From the other post-
      Maybe I was misinformed but I was under the assumption that anodizing was more durable than powdercoating...?
      • Turbo5OhT Offline
        Turbo5OhT Offline
        Turbo5Oh
        the process of anodizing hardens the outer layer of the aluminum makeing it harder to scratch but at .001 thick it is still easy to scratch but will not chip or peel like other coatings, anodizing isnt the process of coloring aluminum, its the process of opening the pores of aluminum to accept color, after color has taken then there is another process of sealing it in
          sry a bit off topic but can a person powdercoat a turbo i knwo they get very hot.. jw
            You can powdercoat the compressor housing, not the exhaust side
              does the exhaust side get to hot?
                yup
                  Is it possible to do an IC?
                    is there anyway to anodize my purple type s bov? i want it blue instead
                    • 9 Offline
                      9 Offline
                      92TSIpos
                      but purple is such a pretty color 😄
                      • harwood39H Offline
                        harwood39H Offline
                        harwood39
                        could you do valve covers or do those have to be powder coated?
                        2730 5th Ave S. Unit C
                        Fargo, ND 58103
                        701-429-3686
                          if its aluminum it can be anodized
                            harwood39H Offline
                            harwood39
                            nope, i dont think its aluminum. its my stock civic one, i wouldnt know.
                            Fargo, ND 58103
                            701-429-3686
                              Would it be ok to anodize wheels or not? I would just be worried about getting the tires mounted on them and the lug nuts messing up the coating. How durable is it compared to powdercoating?
                                you can anodize steel and aluminum so you can do just about any valve cover out there.
                                  Steel cant be done. Most all import vehicles have aluminum valve covers, so most all sahould be able to be done.
                                    Anyone?
                                      Yeah you can anodize wheels no problem. Shouldn't have any problems mounting tires unless you got some retard doing them which in that cause it doesn't matter whats on them their gonna mess it up.
                                      Only kicker on doing wheels is if you want them to look completly perfect w/ no grain of the alum behind them is they basically need to be polished before hand because anyt defect will show. But if you dont mind the grain of the aluminum then leave them as is.
