  4. Meth Injection Q's
Meth Injection Q's
30 Posts 15 Posters 876 Views
    Injection >>> Intercooler
    I'd like to see you get well below ambient IAT's with your A2A IC.........
    while having better boost response and a simpler system, without tearing up your front.....
    There is an awesome thread I should link to on the club..........
    showed a ton of well documented logs (IAT's ect) going from a large FMIC to strictly chemical inection........ showing the results of different mixtures of water and alcohol on IAT's
    great results
    There is no way i am going to run an IC on my car
    not saying A2A IC's are bad or anything, they are a good thing, just not required with a good injection system
      I agree the injection system is just one more thing to worry about, but it does have definite advantages
      and i for one hate intake piping going all over
      • z31Z Offline
        z31Z Offline
        z31
        weshole;245899 wrote:
        Talk to Jason (Z31) about it. He's running it on the Z he has. But I think he's switching to a FMIC. It may be initially easier to do but it's kind of a pita to have to rely on it all the time. Kinda like nitrous.
        Wes, I'm going with Nistune tuning software, E85+Methanol injection, and 9:1 compression pistons for now.
        Like Zack said your Intake Air Temps are going to be below your outside air temp and you can go 30% over your fuel injectors for extra fueling. I think the octane rating is 112
          Why not use an intercooler along with meth injection?
          • no_slow_clapN Offline
            no_slow_clap
            agreed.
            EVOLUTION VIII
              no_slow_clap;245969 wrote:
              agreed.
              because joel just said he didn't want to fit an IC........
              and AI alone has some advantages over running both together
              there are some hardcore fanatics of AI in the rotary world....with unbelievable results
              for instance, on your typical 13b setup with pump gas alone, you are looking at around 15-17psi being your safe ceiling................with a good injection system people are around the area of 25psi on pump gas alone.....all day, every day
                no_slow_clap
                I understand the advantages, but why would you want to substitute cooling for an aditive?
                Joel, your car is going to be down all winter, its not like you wont have time to make something work. you can make your piping...the way you want it, and an ic isnt that expensive. you can buy a good used one one ebay for cheap.
                not only that you dont have to worry about proper applications for your car, you can buy a used side mount and make it work.
                EVOLUTION VIII
                  haha i love these threads, everyone is so afraid of meth injection.
                    Boost response is my #1 concern, sorry for not putting it in my first post. With the Autoxing I do, and the turbo i decided to go with, I am gonna need every advantage I can to be in boost during autox.
                      um, I guess you don't understand what it is doing then
                      when the liquid is vaporized during injection it pulls heat out of the air........among other things
                      Unless that isn't "cooling" the air charge???
                      like i said above Auxiliary Injection can "cool" Intake Air Temps, well below ambient air temperature.... whereas even your best and most efficient A2A setup may get close to ambient temp...... never lower obviously
                      Back with the rotary and the gt42..... when i removed the IC and just ran AI for about a months time it was amazing the difference in boost responce
                        no_slow_clap
                        o that explains a lot more, i always thot meth was alternative source for those that didnt want to run race gas/e85.
                        EVOLUTION VIII
                          meth injection faq
                          http://forums.nasioc.com/forums/showthread.php?p=12614948
                            joel if you really want to be smart, just go with huge injectors and E85, then you dont need to worry abou IC or meth, it really is the best option. Along with the larger exhaust volume associated with E85, it can enable you to go up one exhaust housing size with no difference in spool time, or in your case, a little bigger turbo overall. Most guys running E85 notice close to ambient temps when measured in the runner, which will be more than enough power for you.
                              I like E85, just none around me
                              • 3_Series3 Offline
                                3_Series3 Offline
                                3_Series
                                From the title it almost sounded like he was talking about the drug, haha.
                                2002 Subaru Legacy
                                1993 BMW 325i (sold)
                                • z31Z Offline
                                  z31Z Offline
                                  z31
                                  It is an alternative source. :icon_bigsmurf:
