  4. Honda abs removal??
Honda abs removal??
10 Posts 8 Posters 701 Views
  • wa2fastcamaroW Offline
    wa2fastcamaro
    A friend has a 91 Accord as a winter beater. Its got like 350K on the car and we've been helping it along. Actually still pretty nice for the miles. Well the abs pump assembly has developed a leak, and didn't work in the first place. Remaned unit is $500 and I have been unable to locate a used one. Can I just pull the unit and put t's in the lines from the master cylinder, so it basically does not have abs anymore? Or is there built in porportioning valves and stuff, so it will not work right? Anyone have any ideas?
    Mike
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
      thrash
      did they offer an accord that didn't have ABS in 91? If so, you could check to see of the M/C part numbers are the same. If they are, i think you'll have no problems.
        http://cgi.ebay.com/ebaymotors/HONDA-ACCORD-ABS-PUMP-MOTOR-ASSEMBLY-92-93_W0QQcmdZViewItemQQcategoryZ33560QQihZ019QQitemZ290276677973QQrdZ1QQsspagenameZWDVW
          Get one off a junk one for cheap/free, otherwise you should be fine to just remove it. Im not positive on accords, but most hondas you can just pull it with no problem.
          • 00Accord0 Offline
            00Accord0 Offline
            00Accord
            I had a 91 accord without abs so yeah you can get parts for it no problem. If anything i would say just pull the lines and get a new master cylinder for a non-abs, but I dont think you would even have to do that. Dont forget to pull the abs fuse too.
              i think you should be able to just get rid of it...i know during the summer i just pull my abs fuse as the bumpy ride causes it to go off ALL the time 🙂
                You shouldn't need a new master cylinder, ABS master cylinder are usually slightly larger so it will be fine.
                  wa2fastcamaro
                  after checking around, I found there isn't much for metric brake line parts. So I can't really make anything to take the abs unit out. So I guess I have to buy a used unit. This that sucks is I cannot find anything locally, gunna have to order one from halfway across the country.
                  Phone: 701-371-5615
                    theres an accord for sale in the for sale section. Maybe it has abs. and its less than a reman unit
                    • g2gsG Offline
                      g2gsG Offline
                      g2gs
                      accord abs pump $40 shipped
                      http://www.hondamarketplace.com/showthread.php?t=2443862
