  4. WTB B-series motor
WTB B-series motor
12 Posts 7 Posters 1.6k Views
    Done the swap. Would be willing to do it for $$$ provided everything is there and you don't help. 🙂
      Brink, GSR knows what he's doing when it comes to these type of Motor's. As much as I'd like to give the guy some s*** (just kidding) you should probally enquire about his services in your swap. Nick do you know of any good places that we could look for a good price on a long block B16A2/B18 (not a c5) since we are both in the process of looking at CRX's right now and would both maybe enlist in your services.
        I have always ordered motors from hmotorsonline or jhpusa.
          I have a B16A longblock w/ hydro trans, DC header, ITR intake manifold, BM FPR, Hypertech clutch, yada yada. I wanna get rid of it as i have no use or want for it. Willing to deal....
          Nick
            Another setup you could try that would get you more HP/TQ and is less common is a CRV-Tec. Its a B20 Shortblock with a GSR Head. It's not possible to run a straight B20 either, due to the long intake manifold, it would pop out of the hood. If you decide to run a CRV-Tec I would recommend that you resleeve it.
            CRV-Tec will be faster than ITR(c5) or GSR(c1)
            but thats just my .02 cents
              yes... the mighty mouse!
                Well Tufte we might be very interested in your setup. Just curious if its OBD-1 or what kind of setup you have? Harness as well?
                • FlowcusF Offline
                  FlowcusF Offline
                  Flowcus
                  Actually im extreamly interested in that B16... Could you give me a list of whats done... or better yet call me 701-371-3468 id like to come check it out. The car is pretty much ready for the swap it has the shift linkage, mounts, ECU, but needs a harness. Im waiting for pics on it before buying it but if I do ill definately work a deal on that engine.
                  Peace!
                  Rob
                  I ride random bitches.
                    Because resleeving is so cheap. You're still stuck with a notoriously weak crank, and if you resleeve it why would you put in stock pistons and rods. There's another 1000 bucks w/ bearings. Then once you do that and you go buy your new oil pump, water pump, timing belt, dowel pins, oil feed for the cylinder head, head gasket, etc you're not very cost effective.
                    Stick w/ the B16 if you want one that is local, otherwise my vote would be for an LS swap. Once that's finished you can always add a VTEC head later.
                      Hope you get that Crx Rob. Hows it looking?
