  4. Tire size for width
Tire size for width
55 Posts 16 Posters 1.6k Views
    Sorry I used the wrong year OEM tire size:
    215/40/16 Front
    245/35/16 Rear
    Will get you 22.8" Rolling Diameter All around w/ factory being 22.7".
      Front Tires:
      215/40/16 Toyo T1R
      Rear Tires:
      245/35/16 Toyo T1R
        um a 245 on a stock body miata? i don't think so
          KA-T_240;248521 wrote:
          ^what he said.......
          You make sure the offsets will fit your car properly?
          erik ran 8" 0 offsets all the way aroundon a lowered car with minimal fender rolling. Mine is stock ride height now so it should fit fine. Found a slammin deal on some limited production knock offs made for an 86. http://xxrwheels.com/sportmax_513.shtml#. Those in semi-gloss black with a red lip.
            listen to gsr... if u do slam it cant u roll the fender or put flares on?
            • FG2F Offline
              FG2F Offline
              FG2
              Use this as a reference: http://www.dakota-truck.net/TIRECALC/tirecalc.html
              Keep in mind, that a 245 in say a...Falken isn't always the same as a 245 in say Toyo. Yes it should all be a width of 245, but that is far from the case we have found.
              • Jason
                I based my sizes purely on rolling diameter. I would imagine you're not going to be able to get much more than a 225 on the back of the miata without some work...
                  Are you still putting the flares on the car joel? If so, you can run a 245 in the<u> rear</u> providing you have the ride height set properly. If the ride height is stock, youll have no worries.
                  • BlackEJ8B Offline
                    BlackEJ8B Offline
                    BlackEJ8
                    If you keep it stock height with 8 inch wide 0 offset wheels thats going to look horrible
                    Honda Civic Si - Daily
                      I don't plan on putting the flares on this year. Turboing it, plus new wheels will set me back plenty of money the way it is... I also plan on doing a crazy stereo this year.
                      my stock wheels are 14", these are 16". pretty sure you have no idea wtf your talking about... either way it wont look as gay as a blue crx with yellow wheels...
                      • ihaveaidsI Offline
                        ihaveaidsI Offline
                        ihaveaids
                        A pink crx still wouldn't be half as gay as a miata. And have you ever seen a car on low offset wheels that isn't lowered? I can't imagine how retarded this will look. In for pics.
                          http://www.fargostreet.com/forums/showthread.php?t=16143
                          Ya, you sure know a lot about styling cars. 🙂
                          Joel, throw some red lugs on there! makes sure they stick out a shit ton too. Oh one more thing, make sure your using stock wheels.
                            ihaveaidsI Offline
                            ihaveaids
                            Lol I know that zero offset wheels on a Miata at stock ride height will look retarded.
                              Don't you already have 2 sets of wheels and tires??
                                any fwd honda <<<<<<<<<< stock miata
                                  white 5 zigens are for sale.
                                    1. A Miata is a sports car. it doesnt sit high from the factory.
                                    2. Try lowering a Miata and fitting any kind of wide wheel with a low offset.
                                    3. My car already wears tires bad enough, I dont need retarded amounts of camber to eat my nice tires.
                                      How come your car wears tires so fast? That might be something to figure out before you spend $$$ on more new tires.
                                        Umm.. blue crx with very rare yellow works >>>>>>> miata on fugly knockoffs (are they supposed to be Watanabe/Panasports cause that pic u posted doesnt look close....)
                                        • no_slow_clapN Offline
                                          no_slow_clap
                                          1. miata is a barbie car
                                          2. people have slammed miatas on wide wheels.
                                          3. i thought these wheels were for shows, and didnt you want stretched tires before?
                                          EVOLUTION VIII
