  4. megasquirt
megasquirt
41 Posts 15 Posters 2.7k Views
  • Bp-08B
    Bp-08B
    Bp-08
    im pretty new to this stuff so ill let some pros chime in. lol i tried to type what i was thinking but i am too tired and after i read it, it pretty much made no sense.
    • gsrEKG
      gsrEKG
      gsrEK
      • GoodnbuzzdG
        GoodnbuzzdG
        Goodnbuzzd
        cant use with distributorless ignition???? hmm you can use it with just about anything, with the right parts. building it yourself is part of the fun.
        • T
          T
          thrash
          baro correction is only relevant if you'll be changing altitutdes (or if you drive into a hurricane or something) during the same "boot" of the MS ECU. Otherwise, it reads the base pressure upon bootup and that's what it goes with.
          Last time I had looked, multi-sensor baro correction in MS was quite primitive.
          I think I'd skip fooling with it for your first build, to be honest. I'd also stick with the normal map sensor.
          A distributorless ignition isn't necessarily a problem with MS. On some builds you'd want to read the crank position via the hall sensor on the distributor, but a 60-2 wheel is a better place to read from anyway. For actually getting the spark to the right hole at the right time you've got a few options, espeically if you load the MS2-Extra software into the system.
          I've got a built MS2 setup that I never got around to installing that is forsale, btw.
          • inspector01I
            inspector01I
            Joel;249793 wrote:
            Do you plan on building the MS ECU yourself? Or does the Miata 1.8 lt plug and play work? MAP or Ron will be tuning my car. I would like to have Ron do it, but I just don't know if he'll touch MS or not.
            Im sure ron will do it with a little convincing. I have something to show you and I promise you will never go to MAP.
            I really think on your first build you will have enough to deal with to not have to worry about a barometer setup. Unless you need a new map, i would start with the stock map sensor, and then upgrade when you need to. Saves some money and the start in case you have problems, and possibly saves some headaches if you have any problems with it.
            • D
              D
              dynotune
              i haven't looked @ms software in years, but 4 bar resolution sucks, plain and simple. street cars with 4 and 5 bars do not have proper idle properties and drivabilty ESPECIALLY if you have camshafts or low vacuum @ idle scenarios. Baro correction is generally not needed on street cars, but it is ALWAYS in OEM calibrations and there is reasons for that. Most of the stand alone systems are pretty gross in how they work compared to an OEM quality PMC/ software. Yes, anything you can get will work, but there is many disadvantages to stand-alones in alot of cases.
              DynoTune Speed & Performance
              Mobile chassis dyno service
              www.dynotuneusa.com
              (605) 753-1101
              • bubbaB
                bubbaB
                • JoelJ
                  JoelJ
                  Megasquizz is for cars that don't have engine management. its universal...
                  • bubbaB
                    bubbaB
                    Arent there ones that have been put together to they a plug and play for certain cars...
                    • wesholeW
                      wesholeW
                      Yes they are. Lets leave this thread to the guys that actually KNOW ABOUT THE STUFF. If you dont know, or have a legitimate question pertaining to the thread topic, then stay off the thread.
                      • RidinRailsR
                        RidinRailsR
                        • Bp-08B
                          Bp-08B
                          Bp-08
                          ok he was talking about the miata plug and play megasquirt. yes i bet i could use it but there are some things different. like the miata has distributorless ignition. yes i could switch to distriburtorless igniton but i dont really need to or want to spend the extra money. where the plug n play for the miata is about the same price of the one im getting made for me.
                          • Bp-08B
                            Bp-08B
                            Bp-08
                            thanks for the imput. i will just go with the 3 bar being that i plan on running more than 20psi.
                            • Bp-08B
                              Bp-08B
                              Bp-08
                              also thanks for the input. and thats alright im having someone make me mine that will practicly be plug and play. and yes on their website their baro correction did appear to be kind of ghetto lol
                              • Bp-08B
                                Bp-08B
                                Bp-08
                                • Bp-08B
                                  Bp-08B
                                  Bp-08
                                  • zbrownZ
                                    zbrownZ
                                    • Bp-08B
                                      Bp-08B
                                      Bp-08
                                      • GoodnbuzzdG
                                        GoodnbuzzdG
                                        Goodnbuzzd
                                        well, weather you use the plug-n-play or use the non plug-n-play, if you've never used megasquirt or ms/ms extra software, try and find someone familiar with it to give you a helping hand with it, once you've used and gotten familiar with it you will love it, nothing like being able to tune your car from your laptop. as for my last post on the distributorless ign, i must have missed the fact you were planning on using the plug-n-play for a certain app, wasn't trying to be a smart ass, i was assuming you were going to build/have built a generic megasquirt, so i appoligize there.
                                        • Bp-08B
                                          Bp-08B
                                          Bp-08
                                          thats alright man. the guy building my megasquirt is going to help me out. only problem is it will be over the computer because he is from canada lol. he builds his own plug and play megasquirts for escorts. and dont worry i didnt feel the smart ass vibe lol. but like you said it would be nice to have someone that can hands on help me at first. thats why i posted this to see if there was anyone local. i know i could get it down on my own. but like you say it would definatly be nice to have someone who knows what their doing there lol.
