  4. Is this another common problem with DSMs?
38 Posts 16 Posters 1.2k Views
    I was thinking about that but money is a little tight right now. It would go into every gear except reverse. I think I am going to try and talk my roomies into pushing my car so I can warm up the tranny a little then park it facing out for next time.
    How well does the Syncromesh work? Weshole could you guys put that in for me at Tires Plus?
      syncromesh is just fluid...you flush the system and put in syncromesh...just check the master cylinder see how much fluid is in it...
        It's hard for me to do anything car wise becuase I am not at home and have no real access to a garage.
          well to check the fluid just check the cylinder master or slave...if its low add some dot 3 or 4 fluid......only takes a couple of minutes then pump the clutch to get the air out...maybe that will work
            did you try putting it into 4th and then quickly into reverse? that has worked everytime for me in any car i've driven
              Well I went out and tried it again a little later and it went right in but I will try that next time.
                i have that same problem too. if you can get it so its at least a little bit in.. then hold it and try to back up.. it should pop right in as soon as you start to move.
                  I think I am going to try some Pennzoil Syncromesh. I have read on dsmtuners that it works well and is about $5 cheaper per bottle than the GM stuff even though it is the same stuff.
                    can you get it in reverse when the car is off?
                      I haven't tried that? Why would I do that?
                        its worth a shot isnt it? usually that only is for when like synchros are bad but hey ya never know
                          You sure its the same stuff? Your tranny is worth a good deal more then $15, I dunno...
                            johnson bought it for his car too
                              I just tried and reverse is a little reluctant to go in but it does when it is off.
                              I guess it has the same part # as the GM stuff but is under a different name. I did look into on Dsmtuners.
                                when its running or when its not?
                                  When it was off. So what does it mean then?
                                  • 9 Offline
                                    9 Offline
                                    92TSIpos
                                    i feel your pain man, I went to put my car in reverse and it wouldnt go in at all. Then it overheated because all my "coolant" froze inside the radiator and now its sitting at stop n go :mad:
                                    POS
                                      Ouch that sucks to hear man. Just hope for an early spring.
                                        POS
                                        maybe you should have put some "coolant" in it
                                          Fucking cheap ass, putting near straight water in @ below zero temps...LMFAO. BTW that isnt your fluidyne is it?
