  2. Introductions
  3. Introductions
  4. Sort of new
Sort of new
28 Posts 22 Posters 2.2k Views
  • Evo-lutionE Offline
    Evo-lutionE Offline
    Evo-lution
    Hey alex! I seem to see you somewhere....else haha
    <>2003 WW Evo8<>
    <>2005 Honda Crf50<>
    <>1990 VW Corrado G60<>
    • TeamCrankWalkT Offline
      TeamCrankWalk
      NA is just a hop and skip away haha.
        Welcome
        • gsrEKG Offline
          gsrEKG Offline
          gsrEK
          welcome and i like your username
          2009 Yamaha Zuma 125, gas HOG
          2008 Honda Fit daily
          A s2k
          1991 Honda civic DX Mint SOLD
          1988 Mitsubishi Mighty max
          > BlackEJ8;233529 wrote:
          • 99civic9 Offline
            99civic9 Offline
            99civic
            welcome.. looks clean
            any more pics?
            2000 civic SiR - jdm sickness
            • 3_Series3 Offline
              3_Series3 Offline
              3_Series
              Welcome.
              Mod list?
              2002 Subaru Legacy
              1993 BMW 325i (sold)
                TeamCrankWalk
                Rebuilt 6bolt block with 4bolt rear end.
                Performance Mods.
                HKS 272 exhaust 264 intake camshafts
                Ross Racing 8:5-1 compression forged aluminum pistons
                Eagle H beam rods with ARP hardware
                Polished and balanced crankshaft
                Block bored .030 over
                SS valves
                Magnacore 10mm wires
                NGK BR7ES spark plugs
                Aeromotive FPR with SS lines
                Road race engineering catch can
                Greddy catch can
                Walbro 255hp fuel pump
                Walbro 255hp inline fuel pump
                Rewired fuel pumps
                SS fuel lines
                DSM Link
                Maf Translator
                Eprom ECU
                FIC 650cc injectors
                Aem Uego Wideband
                Turbonetics dual ball bearing 62-1
                2.5 Jet-hot2000 coated o2
                SFP Tubular Manifold coated with jet-hot2000
                Tial 38mm External Wastegate w/ Dump Tube
                Mitsu multilayer metal exhaust gasket
                Push lock style return line with AN fittings
                SS oil feed line
                Mitsu 4layer head gasket
                ARP head studs
                Mitsu timing belt kit
                Mitsu oem gasket kit
                Act 2600 with pressure plate, street disk, mitsu throw out bearing and street light flywheel
                SS clutch line
                CNC extended slave cylinder rod
                Greddy type s bov
                HKS type 1 turbo timer
                Symbroski shift kit
                Reinforced shifter bushings
                2g shift knob
                EGR block of plate
                ABS removed
                Cruise control removed
                All emissions eliminated
                1g non turbo throttle cable
                Full AC system removed
                Autometer 2 and 3/8 phantom boost gauge
                Autometer 52mm phantom oil psi gauge with relocated sender on ss line
                Greddy EGT gauge
                Prothane motor mounts
                Data logger from dsmloggers.com
                Auto meter 2 and 5/8ths carbon fiber gauge cup
                Dash insert to hold SAFC2 and cd player
                Kyb agx struts and shocks
                Ground control coil overs with Eibach springs
                3inch intake pipe
                K&N filter
                3inch GM maf
                CX Racing FMIC w/ short route piping
                1g non turbo throttle body
                Magnus Motorsports heat barrier intake manifold gasket
                Dynamic motorsport engineering rear camber kit
                Energy suspension rear shock bushings
                Clear timing cover
                3inch downpipe with 3inch mandrel bent turbo back piping.
                DNA inline race muffler
                S&W roll cage
                RCI one layer fire jacket
                Driveshaft loop
                Jeggs sealed battery box
                There's probably more, but I haven't updated it in a while.
                Here's a few pictures of what it looks like currently, but some stuff has been removed/replaced since these pictures were taken.
                  Hi 🆒
                  • untitledfolderU Offline
                    untitledfolder
                    What kind of numbers does the Laser put down?
                    > ichibankilla;213613 wrote:
                    2000 Honda Civic CX LS/Vtec
                    http://www.clubredline.net
                    • gsrEKG Offline
                      gsrEKG Offline
                      gsrEK
                      a nice dsm wow. i mean gay dsm haha
                      A s2k
                        welcome dsm'er. ohm is gonna hump your leg
                          TeamCrankWalk
                          Gonna start yelling rape if this keeps up haha. I don't know what numbers its making. Bought the turbo set up from a friend that dynoed some decent numbers untuned and then obviously better tuned so I'm satisfied with the way it sits.
                          • civic91C Offline
                            civic91C Offline
                            civic91
                            welcome
                            04 Toyota Celica Gts
                            • SlowicaS Offline
                              SlowicaS Offline
                              Slowica
                              welcome, quite the mod list there.
                              • kylushK Offline
                                kylushK Offline
                                kylush
                                Welcome.. dsms ftw
                                1998 Z28 Camaro
                                  welcome
                                  • ruthless351R Offline
                                    ruthless351
                                    Welcome!
                                    • fdfreakF Offline
                                      fdfreakF Offline
                                      fdfreak
                                      Holy mod list! Welcome or welcome back
                                      12.645@118mph 12.6psi
                                      • capitljC Offline
                                        capitljC Offline
                                        capitlj
                                        Pretty clean DSM you got there, but I hate it because its red.
                                        Welcome.
                                        > Mitch Hedberg wrote:
                                        2004 Impala LS 3.8
                                          cute turbo....
                                          welcome...
