  4. My 300zx
My 300zx
35 Posts 12 Posters 6.0k Views
    Why did you pull your PS and AC??????
    • D S ohMD Offline
      D S ohMD Offline
      D S ohM
      all that was there when i got the car was cut lines and the pump and compressor. they were useless to me. i have them still, but i dont plan to put them back in.
      I wanna go fast!
        No power steering in a 300zx? Should probably put that back in.
        • D S ohMD Offline
          D S ohMD Offline
          D S ohM
          Why? not that hard to steer without it.
          I wanna go fast!
            Those things are tanks, would imagine power steering would be very nice to have and very easy on the arms...since its not a drag car.
            • D S ohMD Offline
              D S ohMD Offline
              D S ohM
              All of the lines were cut and plugged with bolts and randomness. It would be a lot more work to put it all back in because I would have to find the parts and then pull the motor just to replace half of them. It was just easier to pull the pump out. I have the pump and reservoir if I should ever decide to put it back in with new lines. Its really not too bad to steer though.
              I wanna go fast!
                Matt, no p/s will get old for sure. I'd try to locate the proper stuff to get it back.
                  Pretty much what i was getting at.
                  • D S ohMD Offline
                    D S ohMD Offline
                    D S ohM
                    I hear ya on that. It usually sucks when I'm tired. It might go back in next winter if I keep the car. That's why I kept the pump and reservoir.
                    I wanna go fast!
                      Did they ever make any of them with a manual rack?
                      • D S ohMD Offline
                        D S ohMD Offline
                        D S ohM
                        I need to look into that. It would be nice to have one.
                        I wanna go fast!
                        • capitljC Offline
                          capitljC Offline
                          capitlj
                          Just get a bigger steering wheel problem solved.:D
                          > Mitch Hedberg wrote:
                          2004 Impala LS 3.8
                          • D S ohMD Offline
                            D S ohMD Offline
                            D S ohM
                            Dear god no. Haha. And i dont think they would have come with a manual rack, someone might make one though. These cars came with just about every option available...so im doubting any came with one.
                            I wanna go fast!
                              They all had PS.
                              • Bp-08B Offline
                                Bp-08B Offline
                                Bp-08
                                take out the seals and grease it up and it'll be a lot nicer
                                  I'd check into seeing what they have for aftermarket... IMO manual rack > *
                                  • D S ohMD Offline
                                    D S ohMD Offline
                                    D S ohM
                                    Very true. I dont like power steering very much. Only way I would like to have it is if I were autocrossing.
                                    I wanna go fast!
                                      why powersteering is awsome, it was used for a reason.
                                        god forbid you can parallel park, gotta save that 4 horsepower that your not using unless your turning anyway? ricer mantality
                                          Ricer, thats all i got to say.
