  4. New Stuff
New Stuff
461 Posts 56 Posters 75.2k Views
    shits still weak... forged rods? crank?...... weak
    4 bolt main block 350 1 piece rear main
    line bored and stroked to a 383 3.75 stroke
    eagle 4340 forged rotaing assembly
    6'' eagle forged H-beam rods
    SRP 138093 forged pistons
    Federal H series bearing
    Perfect circle flie fit rings
    Balnced and blueprinted
    ARP Studs all around
    10.8 compression
    RHS Proaction aluminium heads
    Started with 200cc runners
    Full competition port job
    Full Comp valvetrain
    Comp Hyd roller lifters
    Comp .080 hardened molly pushrods
    Comp 152 promag rockers
    SS valves
    Comp dual valve springs
    Ti retainers
    Comp 314 cam .600 lift
    Comp timing kit
    Edelbrock Victor Jr. intake full port and polish
    • z31Z Offline
      z31Z Offline
      z31
      Hang a snail on it. :icon_bigsmurf:
      • JN210J Offline
        JN210J Offline
        JN210
        niiiiiice!!!!!!! that will be kickass
        *1989 Nissan 300ZX Z31 *
        > DelSlow;262050 wrote:
        > I like the new JN210
          • SlowicaS Offline
            SlowicaS Offline
            Slowica
            Parker;256338 wrote:
            why isn't it summer and SLs yet
              Grr;256302 wrote:
              by the way, thats quite the awesome engine stand you got there, where did you get it?
              yep, stole if from some bastard, haha
              huh? rods are forged and the stock nodular cranks have gone 1200whp+
              And i use HP tuners on a 2.5 bar custom SD OS
                yeah... they HAVE gone 1200whp.... but that means nothing... man up, buy a forged crank...
                  it means it will have absolutely no problem at half that power, which i could never use anyway
                  • no_slow_clapN Offline
                    no_slow_clap
                    parker is the king at overkill.
                    EVOLUTION VIII
                      Looks good zac, maybe you'll use your 7, unlike other ppl... lol
                        ive seen ls2 cranks snap at 400whp... but ive seen them take 1000whp....
                        and snap within a year...
                          come on over and drive it...... then you can loose your hearing instead of me 🙂
                            BS..... proof please
                            considering the majority of sponsors build their motors with the OEM crank I am not worried, usually only go to the forged cranks for the 4" stroke
                            then why do you have only have a 4 bolt main?, should have got six..... weak
                              six? i think the aftermarket splayed(spelling) caps will do just fine for when im not driving it...
                              ill just bring you back to the day when i got to say "i told you so" with the 4.8
                              you might need a TII diff BTW...
                                Sounds like waste of money when you have a perfectly good NA one tucked right in there...
                                  yeah... the 7'' diff can take all sorts of abuse.... :icon_scratch: torque, not so much...
                                    Yeah that was sarcasm...
                                    Should just let him keep it, might make for an interesting story some night when hes out and about and it digests itself and then pukes everywhere...
                                      you forgot to hit the sarcasim button....
                                        Well damnit...I'll try to remember that from now on...
                                          good, now we can get back to some nut swinging...
