  4. got the pos running but
15 Posts 7 Posters 783 Views
  • FlowcusF Offline
    FlowcusF Offline
    Flowcus
    Where are the mods at? This is the 2nd thread Gravedigger has hijacked...
    FUCKING BAN GRAVEDIGGER!
    I ride random bitches.
      not my area to mod....
        Done. Gravedigger go whore somewhere else. There are rules. ABIDE BY THEM!
          Nova, did you use a distributor mounting gasket? Also are your valve covers aluminum? If they are, there could be a crack causing your leak.
          • My NOvaM Offline
            My NOvaM Offline
            My NOva
            thats a start thanx there wes they are aluminum 😄 duh didnt think about that but one thing my buddy and i noticed was some steam coming from one of the intake bolts 😕 i know everything got seated but why would that happen?
            oh and yes i did use a gasket ill try for some pics
            Hey Tina come get some hamm
              Take that bolt out and put some thread sealant on it and reinstall and torque it to spec. Then take some brakeclean to the whole area that the oil was going to. Get it totally clean and dry. Then start it up and let it run while watching it. The oil leak should be easy to spot. If that doesnt work, go to napa or other part store and get some engine oil leak tracer dye and pour the whole bottle in. Dont worry it's only a coulple of ounces. Then get a black light and hold it over the engine compartment while the engine is running. It WILL show up then. You dont need a special light for this. If you dont have a black light, just go to walmart and pick up a black light bulb and screw it into any houshold lamp. But beware you will find more leaks than you bargained for.
              • My NOvaM Offline
                My NOvaM Offline
                My NOva
                yeah when i put the bolts in i used thread sealer and as for napa i hate napa
                i havent tryed the dye just yet i need to try to do it when its darker main thing i need is a job man power cant find me a job
                  Today I saw the problem, and its for sure coming out the bolt holes/threads I would talk to Automotive Specialties and see what they tell you to do. I would maybe sign up for the interstate drag way forum and ask on there they, know the v-8's well!!
                  Kevin
                  sls
                    Is it the intake bolts? If so, exactly which ones? You should have six per side. is it drivers side or passenger? is it front, middle or rear?
                    • My NOvaM Offline
                      My NOvaM Offline
                      My NOva
                      middle 1234 bolts that have to be torqued first
