issues boosting
I have a built bottom end with 1g big rods 2g pistons, .2 over bore, hks 272 cams
afcII, 550cc injectors, 14b turbo, sls intercooler piping, intake, 2g mas, k&n fipk, boost controller (spelling?), 2g exhuast manifold, full 3" exhuast with o2 eliminator, 255lph hp fuel pump, afpr, thats all i can think of right now. I think i found one of the boost leaks but it still sputters a little bit, and now I get bad boost spikes. I have it set at 10 pounds and it spikes to 20 pounds. got any ideas? -
do you think that one of your boost leaks is coming from the boost controller?
97Cav wrote:
do you think that one of your boost leaks is coming from the boost controller?Yeah I did make some thing to check for boost leaks and the boost controller was one of them, then I had one between the turbo and j pipe, then I had one on the intake manifold. I fixed them all, the boost controller still leaks a little but at 50 psi, so it shouldnt be an issue.
99slowGSX wrote:
Yep tap it off the Intake manifold. Also you could tap it off the J-pipe.. Have you done a compression check on your new engine? just wondering what you get!Kevin
slsI have a dejon tool j pipe and it doesnt have a tap on it, and no i havent gotten around to doing it yet. Do you have a tester at the shop?
Thanks for the help. -
