  4. Disabling Auto Headlights
71 Posts 18 Posters 9.9k Views
    I wouldnt get HID's unless you have the proper housings...otherwise its retarded.
      look for a fuse for the daytime running lights and pull it. or look for the the DRL relay under the hood. usually a small metal box and unhook it.
        why? I want more light... Will HID's not give me more light?
                  SPANISH-RICE;262319 wrote:
                  O god, another truck with HIDs in a housing pretty much designed to blind people. This will be fun to drive in front of
                  My truck is not very much higher off the ground than most cars... I will make sure to aim them properly...
                  DelSlow;262321 wrote:
                  No Brandon, they are sweet. If you want more light on the road's surface...why not have light spitting in all different directions.
                  Are you mentally retarded? It doesnt matter what kind of bulbs are in your housings... They are all going to reflect the same direction off your reflectors... Unless you have aftermarket projector style housings.
                    Hmmmm....ya sure?
                      DelSlow;262331 wrote:
                      Hmmmm....ya sure?
                      Yeah I am sure. How would a light that is being reflected off the back housing of the headlight change just because of a different type of a bulb...
                        lol
                          if this was a classified you would be getting banned.
                            joel;262333 wrote:
                            yeah i am sure. How would a light that is being reflected off the back housing of the headlight change just because of a different type of a bulb...
                            you do understand how high beams and low beams work on single bulb reflector style housings right? In this argument you are very wrong. And there is absolutly no aiming headlights that glare that badly
                                  HOW IS THAT ONE PLANS TO AIM THIS BLOB OF FUCKERY?
                                    Regardless of all you guys opinions and thoughts on hid's he just asked a question. lets leave it to the answers fellas.
                                      Dont disable the dtr lights. It wont ruin the headlights it will just use them all the time. I guess knock more life off them? But if your goal is ultimatly "more light" then why not always have "more light". Since really its just for the ricer image
                                      besides, dtrl's are for safety. their good to have
                                        This.
                                          the saftey of DRL can be debated. If you search online many studies have been done to show they are not safer. So I wouldnt say that they are making the roads safe. Plus most automakers, like GM, have them because in canada they are required to have them. instead of making more than one light system for the same car they just installed them on every model. saves gm money. which apperantly didnt really help them in the long run anyways. lol
