  4. tech question
tech question
38 Posts 19 Posters 2.2k Views
    Kevin we have stop-tech stage 2 brakes in stock at the shop for a steal if you want to do better brakes. stop in and talk to shane or jason on them.
    here is info on it
    http://www.stoptech.com/products/stage1_2_upgrades.shtml
      I saw you driving a while ago! Its good to see that thing back on the road!
      • no_slow_clapN Offline
        no_slow_clap
        DelSlow;264795 wrote:
        Why's this?
        My explination is terrible, because im basing of my own expierence.
        anyone remember my consistant 14 sec passes in my civic (yes, slow)
        -bald...well shredded street tires, an exploded driver side motor mount, blown struts all around, and full interior.
        with the skunk2 intake mani on, it droped to consistant 15 sec passes. With a higher trap speed, and slower 1/8 mile. this was with street radials, new omnipower coilovers, new motor mounts with inserts from kyle, and a few other things.
        Thats my explination. I dont like them, they are sweet noise makers....thats about it.
        Kevin, you dont need upgraded valve train unless you plan to you RPM's over the stock rev limiter. There are plenty of people that have proved that.
        Not to mention, the kelford 272, and the gsc s2 out perform most 280 cams besides custom grinds.
        Also, i dont think you will need a double pumper with your setup.
        http://forums.evolutionm.net/drag-racing/383601-batmobile-goes-10-67-23psi.html
        this is a friend of mine. Single walbro 255, although on a 2.3. 1000cc injectors, on a race head, with a pump gas tune (the tune is arguable).
        but if you need a double pumper let me know, i can get you one for CHEEAAP.
        EVOLUTION VIII
          ^He needs the double pump for the additional fuel of E85!
          • ColinC Offline
            ColinC Offline
            Colin
            Kevin: I agree with thrash.
            You are the weak spot in this setup. No insult intended, I will also be in this position this summer with a lot less power though lol.
            You have built a car that surpasses you skills as a driver . Better parts and setups might make you car perform better, shave seconds, keep you under control, but they will only be making up for what you lack.
            Go to BIR, sign up for whatever classes you think will help you. Talk to Shane about "race" driving. He's probably the best driver you can easily approach in town. I would imagine he will have some good ideas for you.
            Thrashes ideas are good, but i would think you might want to put some research time into why and how to apply his methods. Except for seat time. Thats easy: you see, you put your butt. . . . . . . into the drivers seat.
            PS: I know a guy who would always be up to caravan all summer long/split hotels or whatever for brainerd trips. I'll get him in touch with you if you'd like.
            • ColinC Offline
              ColinC Offline
              Colin
              oh, and at the level of performance you are talking about, you're going to need experience to choose your parts. As in parts that match your driving style.
                no_slow_clap
                I dont know much about e85.
                Thats why i said on a race head, pump, and a 2.3.
                EVOLUTION VIII
                  boost vs na is completely different in the optimal intake design...... as i am guessing that civic was just motor
                    Yeah, it's usually something roughly around 30% more fuel needed for the same power with E85.
                    BTW, I wasn't trying to be a dick in my previous post lol
                      No, that just comes natural.
                        no_slow_clap
                        your guess was right.
                        which is why i stated my explination is a terrible explination.....and i hate buschur.
                        I would like to see a factory boost intake manifold flow test (evo, gst, tsi...the tt gen s4), against and aftermarket intake mani flow test of the same application. just to see.
                        realistically, a more free flow design would be optimal, but i wanna see what it looks like under real load.
                        Its cool,
                        I was just figuring from injector size.
                        1000cc pump vs 1000cc e85 is something i dont know enough about to compare via fuel charateristics.
                        im betting its like comparing c16 against q16.
                        EVOLUTION VIII
                          thrash
                          (stuff you guys probably already know)
                          The reason you need about 30% more fuel capacity on E85 is because stoichometric combustion for E85 is around 10:1 [10 parts air to 1 part fuel], wheras it is the familiar 14.7:1 for gasoline.
                          spark-fired engines control the amount of air input [via the throttle], and then add the right amount of fuel for the desired combustion. When the fuel is E85, you simply need more gas for the amout of air you've let in.
                          For a given conversion application, the injectors, lines, pressure regulator, and pump(s) are all things that might need to be upgraded, depending on where there is headroom in the existing system.
                          • Sweet-WRX-LovinS Offline
                            Sweet-WRX-Lovin
                            I've got some questions Kevin: Do you have or need an upgraded radiator? Does the evo have any oil starvation problems at higher g sustained cornering? Are the brakes, lines, etc. all stock?
                            Brake cooling ducts are an outstanding idea besides pads, fluid, lines, and removal of the brake dust covers (if it has them). One problem sti's have is flex in the firewall under hard braking at the brake master cylinder location and a master cylinder brace reportedly helps in pedal feel greatly. Thought I would mention this as it might be similar on the evo.
                            Other than a brake makeover get every upgradable suspension and drive line bushing you feel comfortabe in changing out. If any of this is presumptuous I apologize, been geeking out a lot on this stuff lately. Any plans for big weight reduction or a cage? Suppose that depends on how much fun you have this summer huh?
                              Personally if it were me i'd buy the basics that you still need (brakes, tires) run a few races get a feel for how it handles and were it needs improvements and work from there. It's gonna be a lot more difficult to sort out if you've changed everything.
                              • FG2F Offline
                                FG2F Offline
                                FG2
                                Best recommendation I have read in this thread. An EVO or STi stock is too much of a car in stock form for 99% of owners. Drive the car to IT'S limits, then see where it fails you. Before you can drive it to it's limits (in control), a person has a lot of education/seat time.
                                1. Brakes
                                2. Minor Suspension/alignment
                                3. Tires
                                4. Drive it
                                my $.02
                                oh and check out: http://fargostreet.com/forums/showthread.php?p=266001#post266001
                                  Sweet-WRX-Lovin
                                    Sweet-WRX-Lovin
                                    Man that track day sounds like fun.
                                      1. Brakes
                                      3. Tires
                                      4. Drive it
                                      my $.02
                                      I completely agree with that one Jason!! I wish I could have started out doing auto-x with my 240 mostly stock in stead of jumping into it and trying to learn in a fully built car.
