  4. Exhaust options - B.O.
10 Posts 7 Posters 639 Views
  • 63vette6 Offline
    63vette6 Offline
    63vette
    Out the side. Plan 1.
    Under and out. Plan 2.
    • XJHEADX Offline
      XJHEADX Offline
      Is that an extension in the body panel?
        run all 4 pipes out the side like a top fuel drag car i'd say.
        • 63vette6 Offline
          63vette6 Offline
          63vette
          No. That was plan "A" but it blew shit all over the place when it was running so I went under and out. I am just sayin...... heheh. I cut those off and welded turndowns/outs on.
          Probably not as bad if you have doors but in a roadster is was a dusty mess.
          If you decide to go out the sides I still have those 4" rings around here somewhere.
            Plan 2
              This...
              • XJHEADX Offline
                XJHEADX Offline
                If I do that, then I have to get merge dissapators off the turbo's.
                  I like the look of it going out the side of the body. 🙂
                  • 63vette6 Offline
                    63vette6 Offline
                    63vette
                    Out the side is sick as hell, but if I were going to go that route I would try to get it pointed up a few degrees to keep from blowing dust all over the track for the next guy. Down, under and oily could prove difficult if the shit hit the fan. Up like a semi or out the back... heheh 🙂
                    My junk is so slow now it doesnt matter, I may put in oil sprayers in front of the rear tires on a random timer just to keep busy on my half hour drive down the track. 🙂
                    After 22 years my hunk of junk now starts with a key again and has turn signals!!!
                      Out the side for sure
