Meth Injection?
Does anyone know anything about Meth Injection? I have been looking into it lately and from what I hear, it is the cats "MEOW" for rotaries. I know that 100% water will decrease hp but in turn cool your engine significantly. I also read that a 100% meth is like using race gas but also is a cleaner and longer burn but you run the risk of an engine fire (lord knows i dont need that again). I see most people are using a 50/50 mixture (dont know if 50/50 is by volume, mass, or molecular mass) and are having great results with it. Just wanting some insight. I am looking at this AEM kit inparticular, it seems to be fairly popular.
here is some good info
tons of links -
i sold jason one of my kits, i probably ran 150 gallons of meth through it, i think he has run about 40 gallons through it. My first kit i ran about 100 gallons through. Great stuff, really addicting, but you have to set it up right or it will bite you in the ass. What questions do you have?
What kit is that?
I know the aquamist kit is pretty good. and i have heard good things about the Labonte kit as well.
SMC kit is terrible, the pump cant keep up and fail.
no_slow_clap;269931 wrote:
What kit is that?I know the aquamist kit is pretty good. and i have heard good things about the Labonte kit as well.
it a kit made by a company called AEM guess im not sure if you have heard of them you evo guru
Grr;269894 wrote:
i sold jason one of my kits, i probably ran 150 gallons of meth through it, i think he has run about 40 gallons through it. My first kit i ran about 100 gallons through. Great stuff, really addicting, but you have to set it up right or it will bite you in the ass. What questions do you have?I guess the I only have a few questions. Are they difficult to install? At what point after the IC do you tap in the nozzle? directly after the IC or right before the trottle body?
there are alot of options really. If your just running a small shot a single M10 or M15 nozzle can be placed anywhere within 10" of the throttle body, (standard kit) wherever is conveinient. If your running a big shot, 2 M10 nozzles can be used, (dual nozzle kit obviously) i prefer them staggered about 6". If your running a huge shot like i was, you can run 2 M10s in the charge pipe, and one M5 right before the inducer of the turbo. Doing this increases compressor efficiency by about 10%, and does a unreal job of precooling the charge. The Alkycontrol kit, AIS kit, AEM kit, and Snow kit are good. I had a SMC kit once and it wasnt very good. Also, only run 100% meth, mixing it isnt worth it, the gains are from the meth, not the water. I may be getting a new Alkycontrol kit for my TA in the near future, I reccomend that one over all the rest, simply because Julio has the best customer service on the planet. And they can be installed in about 20-40 min, very easy
AI >> A2A IC
You get the shorter charge piping (boost response), detonation resistance, an internally clean engine, and can get a sub ambient IAT with AI.......... with a good A2A IC you can get close to ambient, never lower obviously....and that is about it
granted it is just one more system.....although when i was running mine progressively with the the Haltech it was super simple and the standalone controlled everything
here is an excellent real world comparison, with actual IAT #'s comparing .......... take a look at this thread
F, I cant find it, I forget the OP's name....... but it is an excellent thread in the AI section if you can find it
does it matter at what angle the nozzles are mounted at? I know that the nozzles atomize the alcohol and the boost pressure takes care of the directional path, but just curious if there are any advantages or disadvatages mouting the nozzles at an angle rather than having them orthoganal to the IC piping.
gsrEK;269934 wrote:
it a kit made by a company called AEM guess im not sure if you have heard of them you evo guruwonderfull. good thing i can read, huh.
DelSlow;270009 wrote:
I would have thought the Evo Guru would have known that.I didnt say Meth Guru.
