wanted
Since it's an 88 what motor does it have?
Is it the 2.5L T1 non-intercooled or the 2.2L T2 intercooled?
The tiny mitsu turbo on the T1 is pretty wimpy, but the T3 turbo from the T2 will fit the manifold. The T3 on the Turbo II models is actually good for about 250hp or so.
Also if you have the 2.5L, look into eliminating the BS shafts in the oil pan. It saps a ton of power and really doesn't work that great anyways (they were an afterthought).
Wiz
2.2L Non IC Turbo II, easy upgrade is the IC and piping from the Shelby. But you'll also need the PCM (ECU ) to get the fuel maps right. Also the throttle body from 87-89 3.0L V6 Lebarons, Caravans, etc is an easy bolt on upgrade. Obviously the AC can go since it looks seized. But you'll have to keep the bracket or find/fab up a bracket from a non-AC 2.2/2.5L car since it is the pivot point for the Alt.
This is a great parts site....pretty much the best
http://www.forwardmotioninc.com/
And here is a great forum board:
Wiz
