  4. Guage install help.
Guage install help.
41 Posts 13 Posters 3.5k Views
      • harwood39H Offline
        harwood39H Offline
        harwood39
        Actually i set the diagram up in parallel, with series i would have to take the groun off the first one and connect it to the power on the next and so on. the way they are connected is like taking one wire and splicing seperate wires off of it to connect the power to the guages. same with the ground.
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
          To power up the gauges and the lights on the gauges, you should use a bigger gauge wire than what is supplied just to be on the safe side. Use maybe a 14ga wire for the ignition and ground and then tap off of those for the 4 seperate gauges. And please use solder and tape.
            harwood39H Offline
            harwood39
            i didnt get any wire suplied, i didnt buy the instal kit, i planned on using good wire. I will most likely be using 12ga. i will be using solder, but i am using shrink tubing instead of tape.
            Fargo, ND 58103
            701-429-3686
              use shrink tube and tape....trust me.
                Heat shrink is very good. But then again there is nothing wrong with electrical tape either.
                  pin
                  I now use heat shrink tubing and electrical tape since a clean connection is the most important thing with wiring. The heat shrink tubing doesn't make a perfect seal against the elements, and using tape alone can come apart. I picked up the most expensive model of 3M black electrical tape and it's rated for a wide range of temperatures.
                  Barry
                    Super 33 from 3m is what normally use, and pin is right, to get a really good seal it's a good idea to do both.
                      Also make sure you use autometer's sending units.
                        harwood39H Offline
                        harwood39
                        i want the stock guage for water temp to work tho, and the warning light for the oil preasure to work also. so i take it i cant just plice into the wiring harness? Thats what every one on honda-tech told me i could do.
                        Fargo, ND 58103
                        701-429-3686
                          You cannot just splice into the wires. You can t the sender off of the back of the block though. 1/8 NTP -> -4AN adapter threads into the back of the block where the dummy light sender threads in, then run a 6" -4AN line up to a brass T. Then off of the brass t you will have the stock dummy light sender on one side, and the autometer sender on the other side. I cannot remember if you have to do something similar for the water temp or not...
