Can I really get a ticket for this?
Police are supposed to be alerted of any accident, and yes, you are at fault. No matter what the conditions are, a "rear-end" accident is the fault of the driver in the rear. That driver controls the distance between the cars and is responsible for leaving enough space to stop without causing an accident.
I got a ticket like that last winter. They are stupid but when I went to court I still had to pay. So court was a waste of time and money.. good luck
2wheeler is right..
i remember reading theres supposed to be a certain amount of damage to call the police but i didn't have a problem with it. and i know i'm 100% at fault, my only problem is getting this ticket like there was something i could do. i thought i gave myself more than enough time to stop but it jus wouldnt stop.and thanks to the people who said good luck, i know i'll need it to even have a chance in court here
2wheeler wrote:
Police are supposed to be alerted of any accident, and yes, you are at fault. No matter what the conditions are, a "rear-end" accident is the fault of the driver in the rear. That driver controls the distance between the cars and is responsible for leaving enough space to stop without causing an accident.This is exactly correct according to the law. Driving under the speed limit means nothing as the speed limit is there for IDEAL conditions and is the legal maximum speed you should drive under perfect conditions. He could have also written you a ticket for driving too fast for road conditions. Sorry man, but you are screwed on this one.
2wheeler wrote:
Police are supposed to be alerted of any accident, and yes, you are at fault. No matter what the conditions are, a "rear-end" accident is the fault of the driver in the rear. That driver controls the distance between the cars and is responsible for leaving enough space to stop without causing an accident.No he's not. They should be called if the damage is 1,000 or more. You were following to closely, and not prepared. Learn how to drive, or get better brakes and ABS.
The ticket is legit..my siter got the same thing. The only way she got out of it was because the cop made 12 IM NOT SHITTING YOU 12 mistakes on the police report and was found incompetant. Good luck with fighting the ticket though.
i dont think knowing how to drive is the problem, thats the only accident i ever had. and i gave myself enough time to stop i thought, it just happened. not bad driving, not following too closley it just happened and it was my fault. the ticket still isn't justified in my opinion but oh well, im sure the cop feels better about himself or something. -
In all honesty you have a snowballs chance in hell in trying to overturn the ticket.
cops should only be called if the vehicular damage is 300$ dollars or more and if property damage is 1000$ or more. I have had extensive dealings with this.AHHH Camaro's and Light Poles....
Yeah, they can issue that ticket to you, I've gotten the same thing. BUT, under the circumstances there's a good chance of you getting it dropped in court... atleast reduced.
FYI... they gave it to me for not being in my lane on a right hand turn. Bullshit.
[email protected] wrote:
cops should only be called if the vehicular damage is 300$ dollars or more and if property damage is 1000$ or more. I have had extensive dealings with this.AHHH Camaro's and Light Poles....My bad, the cops didnt get called when i t-boned the f150. he was the one that didnt care to call the cops. Thats prolly cause it was his dads construction companies truck and didnt care. But that helps me alot, no ticket for running a red, and i didnt go through insurance for it.
GraveDigger wrote:
get better brakes and ABS.ABS DOES NOT MAKE YOU STOP FASTER ON ICE. ABS does however allow you to steer while on ice. If you want to stop faster you need to pump the brakes, I know your owners manual tells you not to, but trust me on this one. I pull my ABS fuse every winter (actually, I just have a toggle switch to cut power to my ABS) for this very reason, I did some testing to prove to myself that my ABS is junk...I stopped on average 25' sooner w/o abs using my foot to modulate the brakes than abs did.
Just pay the ticket and forget about it.... a guy at work backed his work van into another car did zero dmg but had to call the cops because its company policy. The cop wrote him a ticket for Improper Backing and it cost him $30.
The pigs will try and squeeze money out of you any way they can.
thats why i love manual brake cars like mine there great u actually stop faster but depends on how well u can drive to contorl it -
The way the court explained it to us is this...
cops can issue the ticked for not having your vehicle under control "AT THE OFFICER'S DISCRETION." Translation: We can fuck you if we want to. How do you like the state of North Dakota now? -
tjamz wrote:
ABS DOES NOT MAKE YOU STOP FASTER ON ICE. ABS does however allow you to steer while on ice. If you want to stop faster you need to pump the brakes, I know your owners manual tells you not to, but trust me on this one. I pull my ABS fuse every winter (actually, I just have a toggle switch to cut power to my ABS) for this very reason, I did some testing to prove to myself that my ABS is junk...I stopped on average 25' sooner w/o abs using my foot to modulate the brakes than abs did.And ive found that every car ive ridden in stops sooner WITH ABS than mine which has none....thats odd. Although cars without ABS seem to stop better than mine as well, so maybe my cars just f'd up.
StangerBanger96 wrote:
And ive found that every car ive ridden in stops sooner WITH ABS than mine which has none....thats odd. Although cars without ABS seem to stop better than mine as well, so maybe my cars just f'd up.from what ive experienced.. i have to agree. my moms camry stops a whole lot better on ice than my talon does or my olds did without abs. i think it really depends on what car it is though. im sure each manufacturer has its own abs system.. so maybe some dont work as well as others.
