  4. s2000 turbo
s2000 turbo
37 Posts 19 Posters 4.7k Views
  • King RicerK
    King RicerK
    how long till you have numbers of it with the turbo? if possible could you post a video of it when done too!!
    Trafik Jamz;299122 wrote:
    • E
      E
      excessive
      its been done for a bit... 317whp on 7 psi.... remember this is on a stock motor so far
        wow that is really pimp. pm sent
        • SmitEvoS
          SmitEvoS
          Did you make that manifold too?
          Brian
          • O
            O
            just my opion, but i think turbocharging an s2000 isn't a good idea... unless the intent is to use it as a drag car. if i were to own an s2000, i'd probably consider a sc or just good i/h/e and raise the compression to 12:1. on another hand... it's all about the driving habits. if there won't be excessive handling needed, then the turbo would be my choice
            • P
              P
              Joey, who's the bald guy installing that front mount :-p.
              • integra_gsr98I
                integra_gsr98I
                Dude, once again...
                BOOST IS FUCKING BOOST.
                Don't matter if it's red, black, blue, or green. Vortech, Garret, Paxton, whatever, positive manifold pressure, is positive manifold pressure.
                And adding a turbo kit and gaining 100+ whp, compared to pulling the motor, putting in new pistons, intake, header, and exhaust, for 12+ whp isn't really worth it.
                • 9
                  9
                  92TSIpos
                  integra_gsr98 wrote:
                  Dude, once again...
                  I was going to say 9 lbs from a sc should be the same as 9 lbs from a turbo.
                  (correct me if i am wrong)
                  • PSiedTSiP
                    PSiedTSiP
                    you are correct sir
                    spanish-rice;237125 wrote:
                    • integra_gsr98I
                      integra_gsr98I
                      Well, sortof. The volume of air being moved @ 9 psi will vary the amount of hp being generated. For instance an s2k with a t25 @ 25 psi will make less power than an s2k with a t3/t67 @ 5 psi.
                      • 9
                        9
                        92TSIpos
                        yeah i suppose if you want to get into detail,but if you match volume of the turbo and sc it should be about the same?
                        • integra_gsr98I
                          integra_gsr98I
                          If flow numbers are similar then psi for psi should be close.
                          • Sweet-WRX-LovinS
                            Sweet-WRX-LovinS
                            Sweet-WRX-Lovin
                            so anyways, very cool mods, bet it sounds badass..... vtec + turbo = wood
                            One time...
                            • S
                              S
                              seanjohn
                              excessive wrote:
                              Picts are of a s2000 we turboed... 307whp on a stock motor tuned with a Aem ems
                              By the way im headed to aem for the advanced training feb 2nd.legacy image
                              Who is we? Is this a shop or something I don't know about?
                              • integra_gsr98I
                                integra_gsr98I
                                Shop is Excessive Autosports in Sioux Falls. We still haven't figured out who the bald guy is yet though. 🙂
                                • stephen bradleyS
                                  stephen bradleyS
                                  stephen bradley
                                  317 in that light car, she should really fly.
                                  • Unknown
                                    i dont think of light car when i think of a convertable.
                                    • vss2kV
                                      vss2kV
                                      vss2k
                                      looks good, is that a custom kit?
                                      Team EMOTION
                                      TSCatalyst.com
                                      • wesholeW
                                        wesholeW
                                        My convertible is 2150 lbs. I think thats pretty light. Now I just need another 200hp.
                                        • wesholeW
                                          wesholeW
                                          My convertible is 2150 lbs fully dressed. I think thats pretty light. Now I just need another 200hp.
