  4. Anyone else using A'pexi Power FC ECU?
12 Posts 5 Posters 1.2k Views
  • fdfreakF Offline
    fdfreakF Offline
    fdfreak
    I am wondering if anyone else is currently running or thinking about running a PFC ecu. I am looking at buying the datalogit which is a user interface that allows you to tune the ECU yourself. anyway, I can either get the rx7 specific or the universal one. I was thinking if i get the universal one, the datalogit might get a little more use if there are other people that would be interested in using it.
    12.645@118mph 12.6psi
      Well i think you answered your own question.
      why NOT get the universal?
      • fdfreakF Offline
        fdfreakF Offline
        fdfreak
        because I can get the rx7 specific for $50 less.
          I know quite a few people running them. From what i have seen, they are decent, but pretty basic. For the price they are pretty good, but I would probably go for something a little more advanced.
            The thing that makes them "basic" is the Commander, talk about worthless. The datalogit makes it A LOT more user friendly.
            • fdfreakF Offline
              fdfreakF Offline
              fdfreak
              the only thing the commander does is change basic settings. The only thing I use it for is to display different settings. Its useful because it will display 1,2,4, or 8 settings all at once. It also allows you to record and change timing and fuel settings. The datalogit allows you to change anything and everything with a computer. IMO the PFC is the best self tuning ECU out there for rotaries, not how they compare with other vehicles.
                Bingo. If I'm not mistaken, it was designed for the RX-7 first. I thought it would catch more steam once the datalogit was developed, but I think it's kind of forgotten in the states, other than maybe in the rotary crowd.
                  Hardly....
                  The Halwin software with self tunning on the Haltech systems makes the PFC look like a kids toy
                  I am with Inspector
                  People have perty good luck with the PFC but it is basic, and the table resolutions are low
                  • fdfreakF Offline
                    fdfreakF Offline
                    fdfreak
                    ^ you must have missed where I said "IMO". Basic, yes. but it allows those of us who are not tunning experts to change crutial settings without having to pay an expert $400 to retune the car. The fc-edit software is clear and very well written. For cars with less than 500hp, I still believe the PFC is great for the rotary.
                    What does the halwin software have that FC-edit doesnt have? Im asking cause I am not familiar with that software.
                      IMO when you look at the similar cost of the PFC setup vs a standalone like AEM or Haltech there just isn't a question which is superior for the money being spent
                      What of these if any can the PFC do?
                      Closed loop idle speed
                      Closed loop electronic boost control
                      Boost per gear
                      NOS enable
                      Intercooler fan
                      Shiftlight
                      Aux. fuel pump
                      Anti-lag
                      Staging signal
                      2 step
                      Turbo timer
                      Load switch
                      RPM switch
                      Intercooler water spray
                      TPS switch
                      Hard and soft cut rev limiter
                      aswell as have
                      4 aux. digital pulsed outputs (for PWM control)
                      3 analogue inputs and 1 digital input
                        Huh? that is an invalid argument
                        you could change the exact same "crucial settings" just as easy or easier with a standalone
                        and the learning curve with Haltech's Halwin that i have been around isn't bad at all
                        IMO HP tuners has a steeper learning curve than Halwin to understand everything......... but once you know a bit about it, I much prefer HPT to Halwin even
                        • fdfreakF Offline
                          fdfreakF Offline
                          fdfreak
                          off the top of my head, fc-edit has the intercooler spray option, anti lag for both ignition and and injection, and TPS switch. anyway, the point of this thread is not to argue which one is better.
                          anyone else have the PFC?
