  3. Wanted Ads
  4. anyone paint cars?
anyone paint cars?
21 Posts 10 Posters 620 Views
  • Bp-08B Offline
    Bp-08B Offline
    Bp-08
    what color? you do realize how expensive paint is right? If you want something really cheap look up the paint roller method, or rattle can. If done right both can look decent.
      what color do you want? I know a guy who does "professional" paint jobs, but will do a $500 dollar paint job for ya, think of it like a maco paint job.
        roller paint looks great when done correctly. but takes alot of time
          ditto, if you have the time it turns out good.
          • C Offline
            C Offline
            Cakija
            id like to go with some red, not real picky on the color as long as its red and shiny
              Cakija;274530 wrote:
              id like to go with some red, not real picky on the color as long as its red and shiny and touch screen
              fixed it for ya
              • fdfreakF Offline
                fdfreakF Offline
                fdfreak
                the primer, paint, and clear alone will run you over $500. if you prep everything yourself you might be able to find someone to do it for a few hundred bucks as long as the only thing they have to do is spray the car.
                12.645@118mph 12.6psi
                  Matt Johnson or something?
                    I vote for roller... cheap, can turn out good if u do it right (it's not hard), only draw back is it can be time consuming...
                      As opposed to 'normal' painting.
                        well depending on the paint job... it takes like 6 coats, and sanding inbetween, and drying time... where as depending on the 'normal' painting... it's a couple coats...
                          Red's pretty simple, i'd have to find out a set price for sure though.
                          • Bp-08B Offline
                            Bp-08B Offline
                            Bp-08
                            Red is the most expensive color paint
                              roller paint isnt supposed to be less than 10 coats. its very thin. wet sand much?
                                well i think josh has been wetsanding every other coat... i was told like 6 coats... I guess we'll see here when we get that far... Either way, much cheaper than getting it sprayed (unless u have a good hookup), but more time consuming (unless ur beaner and spray like 1million different coats on)
                                • C Offline
                                  C Offline
                                  Cakija
                                  let me knnow what you come up with please
