  3. Wanted Ads
  4. anyone paint cars?
anyone paint cars?
21 Posts 10 Posters 918 Views
    what color do you want? I know a guy who does "professional" paint jobs, but will do a $500 dollar paint job for ya, think of it like a maco paint job.
      roller paint looks great when done correctly. but takes alot of time
        ditto, if you have the time it turns out good.
        • C Offline
          C Offline
          Cakija
          id like to go with some red, not real picky on the color as long as its red and shiny
            Cakija;274530 wrote:
            id like to go with some red, not real picky on the color as long as its red and shiny and touch screen
            fixed it for ya
            • fdfreakF Offline
              fdfreakF Offline
              fdfreak
              the primer, paint, and clear alone will run you over $500. if you prep everything yourself you might be able to find someone to do it for a few hundred bucks as long as the only thing they have to do is spray the car.
              12.645@118mph 12.6psi
                Matt Johnson or something?
                  I vote for roller... cheap, can turn out good if u do it right (it's not hard), only draw back is it can be time consuming...
                    As opposed to 'normal' painting.
                      well depending on the paint job... it takes like 6 coats, and sanding inbetween, and drying time... where as depending on the 'normal' painting... it's a couple coats...
                        Red's pretty simple, i'd have to find out a set price for sure though.
                        • Bp-08B Offline
                          Bp-08B Offline
                          Bp-08
                          Red is the most expensive color paint
                            roller paint isnt supposed to be less than 10 coats. its very thin. wet sand much?
                              well i think josh has been wetsanding every other coat... i was told like 6 coats... I guess we'll see here when we get that far... Either way, much cheaper than getting it sprayed (unless u have a good hookup), but more time consuming (unless ur beaner and spray like 1million different coats on)
                              • C Offline
                                C Offline
                                Cakija
                                let me knnow what you come up with please
