  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.2k Views
    Huffers paradise. Impeccable organizational skills you fellas have.
    • capitljC Offline
      capitljC Offline
      capitlj
      bubba;272403 wrote:
      lol, half the hondas i've seen around wont even pass...
      And none of them would be competitive.
      > Mitch Hedberg wrote:
      2004 Impala LS 3.8
      • XJHEADX Offline
        XJHEADX Offline
        You can't say you guys, that would be just me....
          ha, yeah my car is like that too, once its on the ground theres plenty of clearance. That aluminum is tricky isnt it! now and then ill be cruising along nice, then BAM, big ass hole in it
          • XJHEADX Offline
            XJHEADX Offline
            Yanked the mock-up motor last night and pulled the tranny. The tranny will be dropped off at T-N-T Tranmission on Monday just to be checked out. Ted does a hell of a job. Had him do the re-build last summer right after P-10. Had a few runs on it then had it out for other things and he told me to bring it over just so he could take a look. Tore it down, everything looked good, so I put it back in. Figured it was out now so I would have him take another peak at it. Anyways the motor should be ready to be picked up early next week. Still have a lot of wiring to do and some suspension changes yet. I still haven't decided if I am going to change gears or not. Either I'll keep the 3.27's in it or put some 3.08's in it. I did make a custom Tranny crossmember for it the other night. I couldn't get my little Miller 135 to get very good penetration so I dropped it off over to 63Vette for a little tig action.
            Built with a cutting torch and a BFH
            • XJHEADX Offline
              XJHEADX Offline
              Got the motor back last night. Hopefully start bolting some stuff to it in the coming days.
              Had them stuff some Oliver rods in it, they must have been a little beefier than the Eagles, it took 4 slugs of heavy metal.
                looks great........ holy F those valve covers seem tall
                • z31Z Offline
                  z31Z Offline
                  z31
                  Looks good. :icon_cheers: Did you make the oil pan?
                  • C Offline
                    C Offline
                    Cobra Rob
                    As a trained welder you guys look like you know what you are doing
                    • XJHEADX Offline
                      XJHEADX Offline
                      I made it black.. It is a Canton piece "of shit". Another thing that takes a hammer to make fit. Any manufacturer that says bolt-on is a liar.
                      One of us maybe, and it's not me.
                      • z31Z Offline
                        z31Z Offline
                        z31
                        You going to put your car in the all Ford car show at the track?
                        • XJHEADX Offline
                          XJHEADX Offline
                          I was planning on it. Even if not running but it is rollable, I will take it over there.
                          • 63vette6 Offline
                            63vette6 Offline
                            63vette
                            Pretty common for Fords to be pushed to car shows. Bong!!!!!
                            • 63vette6 Offline
                              63vette6 Offline
                              63vette
                              I can weld aluminum between 3 and 5 beers. Any less or any more and I cant. :icon_scratch::icon_scratch::icon_scratch:
                                im in the same boat, i shake too much to weld alum properly unless i have a couple beers first, lol
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  Before I put the intake on I figured it was a good idea to port match it. I took about an 1/8" off two sides of each port. Should have done that along time ago. Had to trim the gaskets too. Wrapped headers last night and tonight. Pulled turbos apart to check them out and cleaned them up.
                                  • C Offline
                                    C Offline
                                    Cobra Rob
                                    as a mustang lover this is very sick keep up the good work
                                    • z31Z Offline
                                      z31Z Offline
                                      z31
                                      That intake elbow going to clear the hood? :icon_scratch:
                                      • z31Z Offline
                                        z31Z Offline
                                        z31
                                        What kinda power will that motor make without the turbos?
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          Hope so, if not I'll get the chop saw out.
                                          When it was N/A it did 485 rwhp @ 6,000
