  4. where can I find sheet metal?
20 Posts 13 Posters 1.7k Views
  • HiImBrianH
    HiImBrianH
    HiImBrian
    Anybody know of anywhere that sells sheet metal for a reasonable price? I'm looking to weld together a sandblasting cabinet and I don't even know where to look.
    Thanks,
    -Brian
    I powdercoat. If it can fit in my oven, I can do it cheap.
    • DelSlowD
      DelSlowD
      Home Depot, Menards, Lowles, Scheels Hardware...so on and so on...
      • JoelJ
        JoelJ
        Thanks,
        -Brian
        Go to gerdau Ameristeel or trudell trailers. Home improvement stores charge ridiculous amounts for metal.
        • HiImBrianH
          HiImBrianH
          HiImBrian
          Thanks, that was the reply I was lookin for! I haven't heard of either of those places, so I'll probably go check em out.
          • darkelvisD
            darkelvisD
            darkelvis
            sheet metal stores
            • DrifterExtremeD
              DrifterExtremeD
              i hate going into gerdau those fuckers treat you like a peice of shit if you don't know everything about the metal they sell.
              there all pricks there
              • capitljC
                capitljC
                capitlj
                Maybe you just need to know more about the metal they sell.
                Mitch Hedberg wrote:
                2004 Impala LS 3.8
                • XJHEADX
                  XJHEADX
                  Not all of them are bad. I just tell them I don't know what the hell I want. I just go pick it out.
                  • DrifterExtremeD
                    DrifterExtremeD
                    i put alot of it on me being young, as with some places car dealers, manufacturing, welding shops. for the most part look down on young people.
                    • Bp-08B
                      Bp-08B
                      Bp-08
                      That is true until the welding shop I worked at got to know me, most people didnt like me because I was young.
                      • 63vette6
                        63vette6
                        63vette
                        Thanks,
                        -Brian
                        If you want a small one you can have mine. What size do you need?
                        • HiImBrianH
                          HiImBrianH
                          HiImBrian
                          Well I'm planning on starting a little biz, so I'd like one that can at least fit a rim...What do you have?
                          • 63vette6
                            63vette6
                            63vette
                            Much smaller. Probably 24"x12"x12"
                            • 94civicex9
                              94civicex9
                              94civicex
                              check with mcnelius steel. i know we get alot of steel from them at dakota fence. not sure if you can just walk in there and buy sheetmetal but its worth a call.
                              Playtime Performance
                              2005 Yamaha R1 [email protected]
                              2009 Zuma 125
                              1995 Honda Civic DX
                              • D S ohMD
                                D S ohMD
                                D S ohM
                                This
                                I wanna go fast!
                                • HiImBrianH
                                  HiImBrianH
                                  HiImBrian
                                  I've kinda changed up my plans a little. I designed a cabinet on pro-e tonight while I was screwin around in the computer lab. I've decided since metal is pretty expensive, that I'm just going to make it outa wood and then get some really thin cheap sheet metal to line the inside to protect the wood. I would need some pretty thick metal if I wanted this to be sturdy and be able to weld it together. This just seems more practical for me.
                                  • XJHEADX
                                    XJHEADX
                                    You're going to eat right through the sheet metal real fast. Do it right the first time..
                                    • inspector01I
                                      inspector01I
                                      I have some diamond plate that I would sell, pm me if your interested.
                                      • T
                                        T
                                        thrash
                                        I have a custom built 4x4x4' cabinet with an expanded steel rotating table. The walls and ceiling are removable and are ductwork sheet metal. It's leaky but i was in a hurry -- i R&R'd and sand blasted about 25 cast iron radiators when i was remodelling my 1896 home last year.
                                        I was using a john-deer hardhat 185cfm diesel trailered compressor and a 300lb instant-seal drum supply. I went through several hundred pounds of black-blast in this cabinet. The galvanic finish on the sheet metal is marred but completely undamaged as near as i can tell. The force of sand out of the nozzle was enough to tip over the radiators if I wasn't careful.
                                        The sheet metal is so cheap that if you somehow wear it out, replacing it is trivial.
                                        I can show you my setup and tell you what works / sucks if you're interested. I had tremendous sand leakage and ended up using it more as a 3 sided backstop than a sealed cabinet. I had to use a chain hoist to load and unload it. The rotating table made working with the heavy radiators considerably more plausible.
                                        • HiImBrianH
                                          HiImBrianH
                                          HiImBrian
                                          PM sent!
