  4. RWD cars+ winter=?????
19 Posts 15 Posters 655 Views
  • E Offline
    E Offline
    Eurofan
    I have had only AWD cars of SUVs in the past. I'am just curious to as how a RWD car handles in the winter with some nice snow tires?? as compared to an AWD/4WD car
      You just have to take it easy on really bad days, otherwise with snow tires you'll be fine.
      I've driven RWD for the past 3 winters with no problems...
      • StangerBanger96S Offline
        StangerBanger96
        I've driven RWD every winter of my 5 year driving life except 1 and prefer it to FWD...
          stick to awd.
          your weiner will stay the same size if you use rwd or awd.
            Drove my MR2 a couple winters ago and it was just fine, using all seasons as well.
            • Bp-08B Offline
              Bp-08B Offline
              Bp-08
              STiSchucky;276305 wrote:
              stick to awd.
              But fwd will make your wiener bigger
                So will a job.
                  or surgery...
                    Extenz?
                    • capitljC Offline
                      capitljC Offline
                      capitlj
                      I had never had FWD or traction control till this past winter, and I gotta be honest I want my RWD back. I never really had too much trouble unless there was a lot of snow on the road, the 265's and all that torque meant that I went nowhere in deep snow. Had I put the stock 215's back on, it would've got around great. With any luck I'll be back to RWD or get to try AWD for the first time this winter. Oh and your balls get bigger if you can handle RWD in the winter, you also learn a helluva lot more about car control.
                      > Mitch Hedberg wrote:
                      2004 Impala LS 3.8
                        proven to enlarge that certain part of the male body.... like your fucking hands.
                        • Bp-08B Offline
                          Bp-08B Offline
                          Bp-08
                          DelSlow;276327 wrote:
                          So will a job.
                          So will your mom
                          • funky_monkey58F Offline
                            funky_monkey58
                            My winter car is RWD and I never had any problems except one time when I parked on a snow bank......
                            Just get winter tires and have fun. Or put winter tires up front and regular tires in the back for controllable fun.
                            • GhettoFabulousCRXG Offline
                              GhettoFabulousCRX
                              snow,, not a big deal.... But I bought a civic to deal with the white stuff anyways
                              1993 Nissan 300ZX- Twin Turbo
                              1995 civic CX
                              2006 Honda CRF50
                              1987 Yamaha Ysr-50
                              1995 Acura Integra sold
                              7 EF civic or crxs sold
                              • C Offline
                                C Offline
                                Cobra Rob
                                cobra does not like the snow so it goes in storage
                                • Afsil80A Offline
                                  Afsil80A Offline
                                  Afsil80
                                  I drove my 240 on Falkens for multiple winters. I never had a problem.
                                  -Peter
                                  1991 240SX
                                    I had studded winter tires for my Lexus and I didnt mind it, still doesnt compare to AWD.
                                    • Chance91C Offline
                                      Chance91C Offline
                                      Chance91
                                      I would agree that If you could, just grab a winter AWD beater. That's my prefered method, easier to swap cars than wheels.
                                      But, if you get a dedicated set of winter wheels with winter tires you can do just fine. I would get the smallest diameter rim you could run on your car if you're able, and then get a rather small treadwidth winter tire. That's typically the recipe for success. Limited slip of any variety helps out a bit as well. On top of all else, take it easy around corners and you should be fine.
                                      I don't see why you would want to run a 265mm wide tire in the winter in a rwd car, likely a sports car, that's just asking for it, really. But hey, whatever floats your boat.
                                      • capitljC Offline
                                        capitljC Offline
                                        capitlj
                                        I ran 265's because I couldn't afford new tires for the 14's and the old ones were bald from my abusive ways.
                                        2004 Impala LS 3.8
