  4. Went out for milk... came home with:
72 Posts 28 Posters 8.4k Views
  • z31Z
    z31Z
    z31
    dubbsy;278047 wrote:
    How about a little info. :icon_scratch:
    year?
    motor?
    trans?
    diff ratio?
    horsepower?
    mods?
    ICE? :icon_bigsmurf:
    • dubbsyD
      dubbsyD
      year?
      motor?
      trans?
      diff ratio?
      horsepower?
      mods?
      as long as someone cares. 🙂
      1995
      86000 miles
      Refreshed 5.0L with forged pistons
      Ported GT40 heads
      E303 cam
      T5 5spd (stock)
      3:73 gear set
      FRPP Alum driveshaft
      Steeda springs
      Bilstein shocks/struts
      Steeda C/C plates
      Steeda weld-in subframes
      Steeda rear sway bar
      BBK 65mm TB
      Paxton SN2000
      42lb Injectors
      Ford GT Fuel pump (310lph)
      BBK shorty headers
      custom O/R H pipe
      Flowmaster catback
      MSD 6a
      Steeda Tri-Ax short throw
      Zoom Stage 2 (sounds like Zoom is the flavorite version of Spec)
      Inside is simple..
      tweecer R/T
      Autometer Phantom Boost and Water temp gauges.
      Short term plans are to fix a couple things. Have the serpentine belt rubbing on a heater hose and the blower belt needs to be aligned (and an idler replaced). Also have to relocate the coolant overflow tank as its rubbing on one of the idlers - which may result in me relocating the battery to the trunk to have a little more room up front. Once all that is done I need to finish getting some break-in miles on the motor (about 350 on it so far) and get it back down to MPLS for tuning. This combo made 405rwhp on the old motor so I'd like to see the same out of it again - although that may have been with the methanol injection set up which I don't plan on using.
      From there, who knows. Would like to do a single turbo and E85. Need to figure out how much fuel upgrades are going to cost me first though.
      • ParkerP
        ParkerP
        i don't think you planned on getting milk...
        BlueSRT0483;244555 wrote:
        Trafik Jamz;260984 wrote:
        You are right Parker.
        • dubbsyD
          dubbsyD
          doesn't everyone take a Wednesday off work and drive to Minneapolis to buy milk?
          • ParkerP
            ParkerP
            not with a trailer.
            • dubbsyD
              dubbsyD
              Parker;278093 wrote:
              not with a trailer.
              I was really thirsty though.
              Trailer didn't come until Saturday anyway. 2 trips to MPLS in a week is enough for me.
              • SPANISH-RICES
                SPANISH-RICES
                any particular reason you dont plan on running the meth kit? just not a fan?
                • dubbsyD
                  dubbsyD
                  no, not really. I'll likely hang onto the parts (unless I find out they're worth some money) in case I change my mind. It's not actually hooked up right now anyway.
                  • zbrownZ
                    zbrownZ
                    Looks nice and clean, and +1 for it not being a mod.
                    on how many #'s does it make the power now?
                    • dubbsyD
                      dubbsyD
                      7-8psi
                      which is about all the blower is capable of.
                      • StangerBanger96S
                        StangerBanger96S
                        StangerBanger96
                        Black mustangs are ugly...
                        • 94NDTA9
                          94NDTA9
                          Holy crap. Awesome pick up man. How much?
                          • STiSchuckyS
                            STiSchuckyS
                            Ill make sure to avoid you on the streets
                            • C
                              C
                              Cobra Rob
                              I have to see this nice Cobra sometime
                              • XJHEADX
                                XJHEADX
                                Nice car Dubbsy. BTW, you better make it two backpacks.
                                • dubbsyD
                                  dubbsyD
                                  lol
                                  Say, you don't happen to have an OEM coolant tank or any idlers laying around from the original setup in the black car do you?
                                  enough.
                                  few hundred above book (stock) but its clean enough I was willing to pay it.
                                  why is that?
                                  • dubbsyD
                                    dubbsyD
                                    • dubbsyD
                                      dubbsyD
                                      • MisterCMKM
                                        MisterCMKM
                                        The car is fun to drive! BTW, get a quadrant and FWA STAT
                                        thrash;315544 wrote:
                                        Ford is back :)
                                        • GrrG
                                          GrrG
                                          very nice dubbs, dont discount the blower yet, its already on there and the SN2000 will make plenty of power
                                          Gary
