  4. Went out for milk... came home with:
72 Posts 28 Posters 8.4k Views
  • dubbsyD
    dubbsyD
    • dubbsyD
      dubbsyD
      • MisterCMKM
        MisterCMKM
        The car is fun to drive! BTW, get a quadrant and FWA STAT
        thrash;315544 wrote:
        Ford is back :)
        • GrrG
          GrrG
          very nice dubbs, dont discount the blower yet, its already on there and the SN2000 will make plenty of power
          Gary
          • dubbsyD
            dubbsyD
            yeah, that's the other thing I need to order... need to get a paycheck in the bank first though.
            Gary
            I just don't like that I can't find much for anything of info on it.
            As long as I can find an idler and get the belt aligned (and decide I can't afford the single 60mm setup this year) I'll probably stick with it for a while.
            • Seven1S
              Seven1S
              Seven1
              Nice car dubbsy!!!
              • dubbsyD
                dubbsyD
                Seven1;278367 wrote:
                Nice car dubbsy!!!
                Shane's still around?
                • capitljC
                  capitljC
                  capitlj
                  Oh yeah he stops into the store to see me about once a month working on his corolla, or the buick, or the caddy. Nice ride I like the stock cobra wheels but you're changing them right?
                  Mitch Hedberg wrote:
                  2004 Impala LS 3.8
                  • dubbsyD
                    dubbsyD
                    not a priority to change them right now because I like them and they're in good shape. We'll see how finances are when I put new tires on them.
                    Josh, are you still at O'Rileys?
                    • GrrG
                      GrrG
                      dubbs idlers are cake, take a pic of it and ill find you one for around $80, otherwise making a different one fit is easy, hell i made my entire pulley system on my car for around $275
                      • dubbsyD
                        dubbsyD
                        Oh I'm not entirely worried about the idler... more-so the fact that it looks to me like the blower isn't aligned properly and I'm not sure how much adjustment I'm going to be able to get out of it. I guess we'll see when I tear into it (hopefully this weekend).
                        • GrrG
                          GrrG
                          if you need some help ill probably be up there sometime PM me your #. I hated blowers too, but once i got it figured out its not bad at all
                          • capitljC
                            capitljC
                            capitlj
                            I like em too dubbsy, just saying I'd want em gone if it were mine, and I wish it were btw. Wheels are the one thing that has the biggest bang for the buck impact on a vehicle's look. I am still with O'Reilly why do you ask?
                            2004 Impala LS 3.8
                            • dubbsyD
                              dubbsyD
                              You were talking about not being last time I was in there talking to you.
                              Might be looking for some parts is why I ask... idler in particular, and I was in there earlier this week looking at prices in an oil pressure gauge and I'll be looking for a full replacement triple A pillar pod.
                              • z31Z
                                z31Z
                                z31
                                dubbsy;278090 wrote:
                                as long as someone cares. 🙂
                                1995
                                86000 miles
                                Refreshed 5.0L with forged pistons
                                Ported GT40 heads
                                E303 cam
                                T5 5spd (stock)
                                3:73 gear set
                                FRPP Alum driveshaft
                                Steeda springs
                                Bilstein shocks/struts
                                Steeda C/C plates
                                Steeda weld-in subframes
                                Steeda rear sway bar
                                BBK 65mm TB
                                Paxton SN2000
                                42lb Injectors
                                Ford GT Fuel pump (310lph)
                                BBK shorty headers
                                custom O/R H pipe
                                Flowmaster catback
                                MSD 6a
                                Steeda Tri-Ax short throw
                                Zoom Stage 2 (sounds like Zoom is the flavorite version of Spec)
                                Inside is simple..
                                tweecer R/T
                                Autometer Phantom Boost and Water temp gauges.
                                Short term plans are to fix a couple things. Have the serpentine belt rubbing on a heater hose and the blower belt needs to be aligned (and an idler replaced). Also have to relocate the coolant overflow tank as its rubbing on one of the idlers - which may result in me relocating the battery to the trunk to have a little more room up front. Once all that is done I need to finish getting some break-in miles on the motor (about 350 on it so far) and get it back down to MPLS for tuning. This combo made 405rwhp on the old motor so I'd like to see the same out of it again - although that may have been with the methanol injection set up which I don't plan on using.
                                From there, who knows. Would like to do a single turbo and E85. Need to figure out how much fuel upgrades are going to cost me first though.
                                Holt shit Dubbsy, it looks stock. Can we see some under hood pictures?
                                • bubbaB
                                  bubbaB
                                  i'd rather look at milk, lol
                                  • GrrG
                                    GrrG
                                    superchargersonline.com
                                    vortechsuperchargers.com, they are way faster but about $10 higher priced.
                                    • dubbsyD
                                      dubbsyD
                                      Dirty as shit thanks to the rain and road grime for 240 miles behind the Tahoe.
                                      The door sill is in the trunk - removed for access to the EEC so he could show off the tweecer R/T
                                      And its so straight (both sides) I'm afraid to take it out of the garage.
                                      Also sounds decent.
                                      [ame]http://www.youtube.com/watch?v=zFn0-s8TR8k[/ame]
                                      • dubbsyD
                                        dubbsyD
                                        I should also add, 12 second car, 14 second driver.
                                        • capitljC
                                          capitljC
                                          capitlj
                                          It does sound good, O'Reilly made a counter offer when I put in my notice so I stayed. Now it sounds like I might be moving to Minot to help run that store.
                                          2004 Impala LS 3.8
