  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 50.9k Views
  • beachbum_jonB Offline
    beachbum_jon
    XJHEAD;278118 wrote:
    It's getting closer. Only a few more things left. Need to finish a few small wiring jobs behing the dash, finish plumbing the AMS-1000, reinstall all dash panels, reinstall interior, set-up suspension and get an alignment done.
    I got a lot of misc. stuff done this weekend. I re-located the tranny cooler from the back to the front and installed a cooling fan on it. Got all the fuel system done. Had the fittings welded in for the blow-off valve and O2 sensor put in. Fabricated new brackets for the shifter cable to work with this shifter. Cleaned up some more wiring.
    I took a look at where that 40 lbs. is at. I think it is way too much work for what it is. It would be a lot of cutting, looks like a job maybe for next winter.
    I am going to try to get it on the road this week to verify the tune. I don't think too much has really changed. If all goes well, I may try to get some launches in this weekend. If launches go well and datalogs look good I may try an attempt at a full pass.
    keep up the good work! this thing is bad ass, i would love to see it. So what is all involved in removing this mysterious 40lbs?
    -John Adams, 1735-1826-
    • XJHEADX Offline
      XJHEADX Offline
      Inside the roof. Pull out all roof reinforcing. I guess some guys cut the roof off first to do it.
      Not quite as light as I was hoping for. It is still 800 lbs.
      • dubbsyD Offline
        dubbsyD Offline
        800 lbs means, what, low 8s now all other things equal?
        That's going to be a hell of an upgrade.
        Still RS/U legal?
        • XJHEADX Offline
          XJHEADX Offline
          Still RS/U legal?
          Yes, still R/S-U legal. Should be low 8's, hopefully I can start bringing in boost sooner and turn it up higher. Had 25 psi in 3rd gear last year.
          • XJHEADX Offline
            XJHEADX Offline
            Well since my junk won't stay running I ordered some more stuff, hope it's needed.
              god damn mustangs, must be nice to just mail-order a premade cage! so since your cutting the roof off you gonna cut that weight out of there?
              • 63vette6 Offline
                63vette6 Offline
                63vette
                Trust me; its not just going to fit in, none of them ever do. They all take a ton of bending and tweaking.
                  Did you ever figure out if the old rollcage was MS or CM? I assume you are just going to cut the old stuff our and start over?
                  • XJHEADX Offline
                    XJHEADX Offline
                    I haven't had is sonic checked yet. Either way it doesn't matter, going to torch the old one out.
                    • XJHEADX Offline
                      XJHEADX Offline
                      Going on this week.
                      • fallguyF Offline
                        fallguyF Offline
                        fallguy
                        XJHEAD;279612 wrote:
                        Going on this week.
                        Look at those cute little things! 🙂
                        Jim- You can use Bill's cage for practice. You can do the really good work on my stang. 😉
                        1990 Ford Probe GT 2jz RWD
                        • XJHEADX Offline
                          XJHEADX Offline
                          fallguy;279624 wrote:
                          You can do the really good work on my STANG. 😉
                          Did I read that correctly???
                          • dubbsyD Offline
                            dubbsyD Offline
                            Going on this week.
                            MT?
                            • XJHEADX Offline
                              XJHEADX Offline
                              dubbsy;279631 wrote:
                              MT?
                              You know it.
                              • 63vette6 Offline
                                63vette6 Offline
                                63vette
                                You know how I am.... Will work for music and beer.
                                I dont need practice with c/m. I have done my share.
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  28 psi 1353 Had 31 in Vegas for 1382
                                  [ame]http://www.youtube.com/watch?v=aXm-pVr_Qwo[/ame]
                                    holy hell....lol
                                    sounds sick
                                      beachbum_jon
                                      was that at andy's in watertown?
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        Yep, last night.
                                          beachbum_jon
                                          alright i thought it looked familiar
