Good day at the dyno
Damn nice numbers.
Nice numbers, you should have kept turning up the boost, 100% duty cycle all the way.....can't wait to see what it runs. What is your injector setup??
meh only quadruple digits? come on dave step it up.. ha jk man sick numbers
i'm already at 41 psi baseline fuel, i'm afraid the pump is going to run out of steam at high boost the way it is.
The red car dyno'd around 600 rwhp. I never had much luck with it on the dyno.
Had a relatively crappy day at th track today, or maybe it's jut been a slow learing process. First pass i launched fairly hard, banged off the wheelie bars and unloaded the rear end... spinning all over at that point. A marvelous 1.9 6"l led to a 9.0 @ 1.63. Turned up the boost a bit and adjusted the wheelie bar, flubbed the launch and had no boost out of th hole ( pro tree can be a bugger), ran a 8.73 @ 165. Last pass I turned the boost up a tad more (36 psi finally), but the car hickuped at the launch, shitty 60' and ran a 8.51 @ 168.
The good thing was the traps 168 on 36 psi of boost, where last year it took 42 psi plus 150 shot.
DaveH;279929 wrote:
i'm already at 41 psi baseline fuel, i'm afraid the pump is going to run out of steam at high boost the way it is.The red car dyno'd around 600 rwhp. I never had much luck with it on the dyno.
Yep, I just looked at the charts, the Weldons do not like a lot of pressure. It looks like I may have to go back to my ACCEL pump and dump the 2035. The Accel draws a lot less amperage too. Doesn't make sense to me.
Get that thing dialed in a bit more with some seat time and you will be there.
12x1000cc and let her buck.
integra_gsr98;279953 wrote:
12x1000cc and let her buck.Wouldn't that be the same amount of fuel at WOT?
^ I take it you also have been on site when injectors are flow tested?
