  4. A few pics from the auto-x
23 Posts 13 Posters 4.0k Views
  • GoodnbuzzdG Offline
    GoodnbuzzdG Offline
    Goodnbuzzd
    Like the title says:
      kevin, how did you do auto crossing the evo?
      • beachbum_jonB Offline
        beachbum_jon
        that is thee most redneck auto-x iv ever seen. you know your in the midwest when there is combines lining the auto-x course...
        -John Adams, 1735-1826-
        • ruthless351R Offline
          ruthless351
          Heres a few i took......
          Where is Freitag going?
            ruthless351
            Will have videos up soon.......converting formats
              Kevin, did you get those Dunlops? How did they perform? Pic looks like Azenis on there.
              • HiImBrianH Offline
                HiImBrianH Offline
                HiImBrian
                Here's the pics I took while I was there. Pics are off an lg dare, but it's all I got.
                I powdercoat. If it can fit in my oven, I can do it cheap.
                  HiImBrianH Offline
                  HiImBrian
                  I've got a couple vids too, but for some reason I can't transfer those via bluetooth so I'll have to get em on my comp laterz.
                    aliengotpsi
                    I ran the 615's 245 45 17 seem to be ok... I need some help with setting up my suspension and swaybars as the car cant get the rear to pop out of the corners... I heard I took 5th overall which I think is good for a car that is not set up for AutoX..
                    Kevin Smith
                    Straightlinedetailing.com
                      how adjustable are your sway bars Kevin?
                      • no_slow_clapN Offline
                        no_slow_clap
                        Kevin, take a look at this when you get a chance.
                        http://forums.evolutionm.net/brakes-suspension/335821-under-steering-auto-x.html
                        EVOLUTION VIII
                          Kevin, you did get 5th in raw times. For future events you should class your car. It would be in SM.
                            aliengotpsi
                            I have hotchkis rear sway bar with 3 adjustments and the front is stock with 2 adjustments Suspension is JIC FLA-2 with spring preload, 12 way dampining and trunk bracing. I want to get rid of oversteer and have the rear end kick out more. I think the front camber plates are -2.
                            Kevin Smith
                              Wouldn't oversteer in fact CAUSE the rear to "kick out" more?
                              • drift86D Offline
                                drift86D Offline
                                drift86
                                It is understeering. Not oversteer.
                                AE86 project: sold
                                93 r33 gts25t new project
                                00 impreza obs
                                  no_slow_clap
                                  OMG!
                                  EVOLUTION VIII
                                  • drift86D Offline
                                    drift86D Offline
                                    drift86
                                    I was going off his last post and what wes said. Didn't read you link.
                                    AE86 project: sold
                                    00 impreza obs
                                      no_slow_clap
                                      so was i.
                                      EVOLUTION VIII
                                        Also try practicing on your own. Barking before turn in, hitting proper apex of the corner, etc. A little driver practice can go a long way. Find an unoccupied parking lot and grab a couple of cones and do to town. I did that back when I had the Miata and I got to learn my car a lot.
                                        • C Offline
                                          C Offline
                                          Cobra Rob
                                          it was my first time and i had a blast
