boost creep vs turbine housing AR
haha, i will say i was wrong based on your response's. but i still think for the car me and zac talked about. it would have fixed the problem. but might be bad if generalized for every situation.
it was a civic with a ls motor. running a afi turbo kit, 57 trim 60/63, v-band 38mm gate.
guy was trying to run 7 lbs and was creeping to 10-11 lbs. Also he is running stock redline 7200 and map sensor.
So i had mentioned switching to the small a/r as it will spool sooner and help wastegate flow. all the larger housing will do in this case is slow down the turbine and increase lag.
So there might be 2 ways to go about solving the problem. but in this case i think the smaller a/r is the way to go.
still think it is crazy it makes 4 psi without the wastegate on at all.
yes it was on honda-tech
drifterextreme;286402 wrote:
still think it is crazy it makes 4 psi without the wastegate on at all.that has some serious flow issues through that wastegate elbow then. Thats nuts
funny thing is it is a afi ramhorn. pretty standard manifold. so i think this guy is smoking crack, or something is up
